1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: using et_wish for temperature monitoring
To: EPICS Tech Talk <[email protected]>
Date: Mon, 26 Aug 2013 18:04:04 -0500
Nalaka:
On 8/25/2013 9:38 AM, nalaka samarasinghe wrote:
Many thanks for the information. I started off with MEDM for my control
system research work but found that it is not capable of applications
involving timing such as maintaining temperature profiles. Therefore, i
decided to work with et-wish.
MEDM is a thin client for EPICS. It does not provide any programming capability to the user. If you wish for a "thick" client on which you can do programming or scripting, there are many to choose from. For my work, et_wish is no longer the modern thick client of first choice. There are scripting capabilities in Control System Studio, for example. Or you could build your own tools from a C++/Qt framework such as epicsQt or possibly build Python applications or some other higher level application. The EPICS website has a list.
Often, you might consider adding into a client a capability which could be used by other EPICS tools at your site. In this case, reconsider adding that capability directly into an IOC to the benefit of _any_ client. The EPICS Application Developer's Guide is one reference for you, after the Getting Started with EPICS training online (http://www.aps.anl.gov/epics/docs/GSWE.php).
For timing involving maintenance of a temperature profile, I assume you are interested in building a temperature controller in software? Consider using the epid record in an IOC:
  http://cars9.uchicago.edu/software/epics/epidRecord.html
   Pete
Pete R. Jemian, Ph.D.                <[email protected]>
Beam line Controls and Data Acquisition, Group Leader
Advanced Photon Source,   Argonne National Laboratory
Argonne, IL  60439                   630 - 252 - 3189
   Education is the one thing for which people
      are willing to pay yet not receive.
Re: using et_wish for temperature monitoring Pete Jemian
Prev: ICALEPCS Agenda - Ann Keffer
Next: How to execute opi files? Yasemin Barutçu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: using et_wish for temperature monitoring Pete Jemian
Next: Segmentation fault et_wish nalaka samarasinghe
