1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice communication problems
To: [email protected]
Date: Tue, 27 Aug 2013 09:57:41 +0200
Hello Tito,
Which asyn version are you using?
Dirk
On 26.08.2013 17:33, Tito Körner wrote:
Hello,
I am using Streamdevice (
http://epics.web.psi.ch/software/streamdevice/doc/index.html) to control a
high voltage box. The box has 5 levels with 8 channels each, so it controls
40 channels. The boxes receive commands and send output via telnet.
Currently I only have two records - one for reading one for writing values.
To access all channels I use a template. The problem is whenever I give one
channel the command to change the value - the entire traffic gets mixed up:
My .db looks like this:
record (stringout, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):set_volt")
     field (DTYP, "stream")
     field (OUT,  "@$(PROTO) set_voltage($(LEVELNO),$(CHANNELNO))
termBox$(BOXNO)")
record (ai, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):read_volt")
     field (INP, "@$(PROTO) read_voltage($(LEVELNO),$(CHANNELNO))
termBox$(BOXNO)")
     field (SCAN, "1 second")
     field (FLNK, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):read_volt")
     field (PACT, "")
     field (STAT, "")
     field (SEVR, "")
     field (VAL, "")
My protocol file looks like this:
terminator = CR LF;
LockTimeout = 10000;
read_voltage {
     out "read_adc floats_csv \$1 \$2";
     in "%*d.%*d.%*d %*d:%*d:%*d,%f";
     @mismatch{out "read_adc floats_csv \$1 \$2";  in "%*d.%*d.%*d
%*d:%*d:%*d,%f";}
set_voltage {
     out "SetVpmF \$1 \$2 %s";
     in "DAC: \$1   CH: \$2   U: %*f  Uk: %*f";
     in "Nachregelung aktiv!";
     in "Messwert: %*f   DAC: \$1   CH: \$2   Value: %*f   korrigiert: %*f";
I created a python script that prints all values to the terminal. As long
as only the read record is activ everything works out. But when I use
another terminal to set a voltage like: 'caput
CB:HV:BOX:19:0:0:1480:set_volt' the voltage values start to  'jump around'.
I monitored the network traffic with wireshark and saw this:
read_adc floats_csv 2 5
01.01.1900 04:23:55,1345.003
read_adc floats_csv 2 6
01.01.1900 04:23:55,1345.123
read_adc floats_csv 2 7
01.01.1900 04:23:55,1345.156
read_adc floats_csv 3 0
01.01.1900 04:23:56,1346.075
read_adc floats_csv 3 1
01.01.1900 04:23:56,1343.827
read_adc floats_csv 3 2
01.01.1900 04:23:56,1376.977
read_adc floats_csv 3 3
01.01.1900 04:23:56,1346.537
read_adc floats_csv 3 4
01.01.1900 04:23:56,1341.462
read_adc floats_csv 3 5
01.01.1900 04:23:56,1368.079
SetVpmF 0 0 1480
*read_adc floats_csv 3 6 *
DAC: 0   CH: 0   U: 1480.000  Uk: 1584.800
Nachregelung aktiv!
Messwert: 1479.545   DAC: 0   CH: 0   Value: 1480.350   korrigiert:
1585.165
Messwert: 1479.941   DAC: 0   CH: 0   Value: 1480.395   korrigiert:
1585.212
Messwert: 1479.935   DAC: 0   CH: 0   Value: 1480.445   korrigiert:
1585.264
Messwert: 1480.045   DAC: 0   CH: 0   Value: 1480.410   korrigiert:
1585.228
Messwert: 1480.046   DAC: 0   CH: 0   Value: 1480.375   korrigiert:
1585.191
Messwert: 1479.941   DAC: 0   CH: 0   Value: 1480.420   k*read_adc
floats_csv 3 6 *
orrigiert: 1585.238
Messwert: 1480.052   DAC: 0   CH: 0   Value: 1480.379   korrigiert:
1585.196
Messwert: 1479.963   DAC: 0   CH: 0   Value: 1480.408   korrigiert:
1585.226
Messwert: 1480.063   DAC: 0   CH: 0   Value: 1480.359   korrigiert:
1585.175
Messwert: 1479.963   DAC: 0   CH: 0   Value: 1480.388   korrigiert:
1585.205
read_adc floats_csv 3 7
01.01.1900 04:23:59,1344.063
read_adc floats_csv 4 0
01.01.1900 04:23:59,1344.070
read_adc floats_csv 4 1
01.01.1900 04:23:59,1346.169
read_adc floats_csv 4 2
01.01.1900 04:23:59,1357.607
read_adc floats_csv 0 0
01.01.1900 04:24:00,1352.217
read_adc floats_csv 0 1
01.01.1900 04:24:00,1340.962
As you can see (marked bold) in between the command 'SetVpmF 0 0 1480' and
the response from the box there are two out commands from the read_volt
record. The problem now is - the first response from the box after the
response to the set_voltage command is '01.01.1900 04:23:59,1344.06. This
is actually the voltage value belonging to the command 'read_adc floats_csv
3 6'. But because the read_volt record sent this command in between the
command and response of  the set_volt record, Epics 'thinks' this is the
value for 3 7. At the StreamDevice website it says that a protocols first
out command locks the device for exclusive access until the protocol is
finished. But here this does not seem to work because obviously the
read_volt record sends the out command of its protocol while the protocol
called in the set_volt record is active. I hope someone can help me to
figure out what's going wrong and how to fix it.
Tito Koerner
Re: StreamDevice communication problems Tito Körner
Prev: How to execute opi files? Yasemin Barutçu
Next: TPG261 : "message too small=0" for EPICS Sanguk Won
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: StreamDevice communication problems Fabian S.
Next: Re: StreamDevice communication problems Tito Körner
