> the correct command would be
> var streamDebug=1
No, the correct command is
var streamDebug 1
The = is not allowed.
From: [email protected] [[email protected]] on behalf of Burkhard Kolb [[email protected]]
Sent: Wednesday, August 28, 2013 7:55 AM
To: Tito Körner
Cc: tech-talk Mailing List
Subject: Re: StreamDevice communication problems
Hi Tito,
var streamDebug=1
Do I understand it right that you get the values for 8 channels with one read?
You would need to include these responses and sort them into different records by specifying
the record names in the protocol.
Burkhard
Dr. Burkhard Kolb
Tel +49 6159 712667
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 | D-64291 Darmstadt | www.gsi.de<http://www.gsi.de>
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführung: Professor Dr. Dr. h.c. mult. Horst Stöcker, Peter Hassenbach
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Am 28.08.2013 um 14:38 schrieb Tito Körner:
Hi everyone,
Thanks for the replies.
@ Mark Rivers: This FLNK field is just a relict from my very first attempts. This FLNK should keep the record going even though there is a mismatch. Using the SCAN field it is pretty unnecessary I admit, but it shouldn't be responsible for my problem - however I deleted the line now.
@ Fabian S.: I tried to enter "streamDebug=1" at the epics console but I got the message "Command streamDebug=1 not found".
I don't really thinkg the output really appears in the input. When I take a look at the packages sent via telnet it looks like the out commands from the read_volt record are sent in between the out and in command from the set_volt record.
@ Dirk Zimoch: I'm using asyn4-21.
As I see it my problem is that the device is not locked by a protocole once the first out command is sent (or may I just don't understand locking correctly) and that the response to the out command of read_volt is not unique for a specific channel (like it for example would be when the level and channel number would be part of the output - then I could parse these values.
I can't change the strings coming from the box unfortunatelly. So is there a away to actually check how and if a protocol really locks a device? Or is there the possibility to somehow manually lock the box - with a field for example.
I'm also thinking of using the DISA und DISV field. My basic idea would be to stop the read_volt record via first writing to the DISA/DISV field in the read_volt record so it no longer processes, then set the voltage and restart the read_volt record afterwards. I guess it may possible somehow.
Tito
2013/8/27 Dirk Zimoch <[email protected]<mailto:[email protected]>>
Hello Tito,
Which asyn version are you using?
Dirk
On 26.08.2013 17<tel:26.08.2013%2017>:33, Tito Körner wrote:
Hello,
I am using Streamdevice (
http://epics.web.psi.ch/software/streamdevice/doc/index.html) to control a
high voltage box. The box has 5 levels with 8 channels each, so it controls
40 channels. The boxes receive commands and send output via telnet.
Currently I only have two records - one for reading one for writing values.
To access all channels I use a template. The problem is whenever I give one
channel the command to change the value - the entire traffic gets mixed up:
My .db looks like this:
record (stringout, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):set_volt")
field (DTYP, "stream")
field (OUT, "@$(PROTO) set_voltage($(LEVELNO),$(CHANNELNO))
termBox$(BOXNO)")
record (ai, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):read_volt")
field (INP, "@$(PROTO) read_voltage($(LEVELNO),$(CHANNELNO))
termBox$(BOXNO)")
field (SCAN, "1 second")
field (FLNK, "$(P):BOX:$(BOXNO):$(LEVELNO):$(CHANNELNO):read_volt")
field (PACT, "")
field (STAT, "")
field (SEVR, "")
field (VAL, "")
My protocol file looks like this:
terminator = CR LF;
LockTimeout = 10000;
read_voltage {
out "read_adc floats_csv \$1 \$2";
in "%*d.%*d.%*d %*d:%*d:%*d,%f";
@mismatch{out "read_adc floats_csv \$1 \$2"; in "%*d.%*d.%*d
%*d:%*d:%*d,%f";}
set_voltage {
out "SetVpmF \$1 \$2 %s";
in "DAC: \$1 CH: \$2 U: %*f Uk: %*f";
in "Nachregelung aktiv!";
in "Messwert: %*f DAC: \$1 CH: \$2 Value: %*f korrigiert: %*f";
I created a python script that prints all values to the terminal. As long
as only the read record is activ everything works out. But when I use
another terminal to set a voltage like: 'caput
CB:HV:BOX:19:0:0:1480:set_volt' the voltage values start to 'jump around'.
I monitored the network traffic with wireshark and saw this:
read_adc floats_csv 2 5
01.01.1900 04:23:55,1345.003
read_adc floats_csv 2 6
01.01.1900 04:23:55,1345.123
read_adc floats_csv 2 7
01.01.1900 04:23:55,1345.156
read_adc floats_csv 3 0
01.01.1900 04:23:56,1346.075
read_adc floats_csv 3 1
01.01.1900 04:23:56,1343.827
read_adc floats_csv 3 2
01.01.1900 04:23:56,1376.977
read_adc floats_csv 3 3
01.01.1900 04:23:56,1346.537
read_adc floats_csv 3 4
01.01.1900 04:23:56,1341.462
read_adc floats_csv 3 5
01.01.1900 04:23:56,1368.079
SetVpmF 0 0 1480
*read_adc floats_csv 3 6 *
DAC: 0 CH: 0 U: 1480.000 Uk: 1584.800
Nachregelung aktiv!
Messwert: 1479.545 DAC: 0 CH: 0 Value: 1480.350 korrigiert:
1585.165
Messwert: 1479.941 DAC: 0 CH: 0 Value: 1480.395 korrigiert:
1585.212
Messwert: 1479.935 DAC: 0 CH: 0 Value: 1480.445 korrigiert:
1585.264
Messwert: 1480.045 DAC: 0 CH: 0 Value: 1480.410 korrigiert:
1585.228
Messwert: 1480.046 DAC: 0 CH: 0 Value: 1480.375 korrigiert:
1585.191
Messwert: 1479.941 DAC: 0 CH: 0 Value: 1480.420 k*read_adc
floats_csv 3 6 *
orrigiert: 1585.238
Messwert: 1480.052 DAC: 0 CH: 0 Value: 1480.379 korrigiert:
1585.196
Messwert: 1479.963 DAC: 0 CH: 0 Value: 1480.408 korrigiert:
1585.226
Messwert: 1480.063 DAC: 0 CH: 0 Value: 1480.359 korrigiert:
1585.175
Messwert: 1479.963 DAC: 0 CH: 0 Value: 1480.388 korrigiert:
1585.205
read_adc floats_csv 3 7
01.01.1900 04:23:59,1344.063
read_adc floats_csv 4 0
01.01.1900 04:23:59,1344.070
read_adc floats_csv 4 1
01.01.1900 04:23:59,1346.169
read_adc floats_csv 4 2
01.01.1900 04:23:59,1357.607
read_adc floats_csv 0 0
01.01.1900 04:24:00,1352.217
read_adc floats_csv 0 1
01.01.1900 04:24:00,1340.962
As you can see (marked bold) in between the command 'SetVpmF 0 0 1480' and
the response from the box there are two out commands from the read_volt
record. The problem now is - the first response from the box after the
response to the set_voltage command is '01.01.1900 04:23:59,1344.06. This
is actually the voltage value belonging to the command 'read_adc floats_csv
3 6'. But because the read_volt record sent this command in between the
command and response of the set_volt record, Epics 'thinks' this is the
value for 3 7. At the StreamDevice website it says that a protocols first
out command locks the device for exclusive access until the protocol is
finished. But here this does not seem to work because obviously the
read_volt record sends the out command of its protocol while the protocol
called in the set_volt record is active. I hope someone can help me to
figure out what's going wrong and how to fix it.
Tito Koerner
- StreamDevice communication problems Tito Körner
- Re: StreamDevice communication problems Dirk Zimoch
- Re: StreamDevice communication problems Tito Körner
- Re: StreamDevice communication problems Burkhard Kolb
RE: StreamDevice communication problems Mark Rivers
<2013>
2025
2026
<2013>
2025
2026
