1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motor record: soft motor & DMOV
To: Kevin Peterson <[email protected]>
Date: Wed, 28 Aug 2013 18:12:30 +0000
Hi Kevin,
> When a soft motor is commanded to move, it is the motor record that
> initially set the DMOV to zero; the value of DINP PV is ignored at
> this point.  The first time the DINP PV is used is the first status
> update after the move is initiated.  If the moving-poll rate of the
> real motors is high,
60 Hz in my case
> there can be a very narrow window during which the DINP calc must be
> done.
Sorry, I don't get it, yet. Can you please describe a bit more detailed
how it is supposed to behave and in contrast to that what you think
happens if it fails?
> In "soft motor record.db" the DINP field is set to
> "$(PREFIX):doneMoving_". How is $(PREFIX):doneMoving_ calculated?
record(calc, "$(PREFIX):doneMoving_") {
   field(CALC, "A && B")
   field(INPA, "$(PREFIX):motorRadPiston.DMOV CP MS")
   field(INPB, "$(PREFIX):doneMovingGate_ NPP MS")
record(bo, "$(PREFIX):doneMovingGate_") {
   field(FLNK, "$(PREFIX):doneMoving_")
record(calcout, "$(PREFIX):doneMovingCloseGate_") {
   field(CALC, "A")
   field(INPA, "$(PREFIX):motorAngPiston.DMOV CP MS")
   field(OUT, "$(PREFIX):doneMovingGate_ PP MS")
   field(OOPT, "Transition To Non-zero")
   field(DOPT, "Use OCAL")
   field(OCAL, "1")
This is inspired by a mail by Tim
(http://www.aps.anl.gov/epics/tech-talk/2008/msg00127.php). I hope I
implemented it the right way...
Martin
Re: motor record: soft motor & DMOV Ron Sluiter
Re: motor record: soft motor & DMOV Kevin Peterson
motor record: soft motor & DMOV Konrad, Martin
RE: motor record: soft motor & DMOV Mooney, Tim M.
Prev: Re: motor record: soft motor & DMOV Kevin Peterson
Next: Re: motor record: soft motor & DMOV Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
