1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motor record: soft motor & DMOV
To: "Mooney, Tim M." <[email protected]>
Date: Wed, 28 Aug 2013 11:57:12 -0500
On 8/28/13 12:26 AM, Mooney, Tim M. wrote:
> Also, DMOV is cleared in special(), before motion ever starts, so
> that there will be a guaranteed 1-0-1 transition of DMOV in response
> to a write to VAL - even if the write doesn't cause any motion (for
> example, because the new value isn't different enough from the old
> value).
This is a very important point that doesn't get enough attention.
When a soft motor is commanded to move, it is the motor record that
initially set the DMOV to zero; the value of DINP PV is ignored at this
point.  The first time the DINP PV is used is the first status update
after the move is initiated.  If the moving-poll rate of the real motors
is high, there can be a very narrow window during which the DINP calc
must be done.
In "soft motor record.db" the DINP field is set to
"$(PREFIX):doneMoving_". How is $(PREFIX):doneMoving_ calculated?
Kevin
motor record: soft motor & DMOV Konrad, Martin
RE: motor record: soft motor & DMOV Mooney, Tim M.
Prev: EPICS support for USB TMC (Test & Measurement Class) devices Eric Norum
Next: Re: motor record: soft motor & DMOV Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: motor record: soft motor & DMOV Mooney, Tim M.
