1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motor record: soft motor & DMOV
To: Kevin Peterson <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 29 Aug 2013 18:26:40 +0000
Hi Kevin,
thanks for your detailed explanation of these issues. That in mind, I
was looking into the behavior of my system again and discovered another
problem regarding DMOV/DINP:
I need to be able to do the following types of writes to the soft motors:
1. write to soft motor 1
2. write to soft motor 2
3. open gate and write to soft motor 1 immediately followed by a write
to soft motor 2 (a fanout record triggers two output records to write to
both soft motors "at the same time")
I also need to be able to directly adjust the real motors:
4. write to real motor 1
5. write to real motor 2
When I implemented the gating logic I thought
realMotor1.DMOV && doneMovingGate_
would be enough. But this does not behave correctly in case 5. So I
changed it to
realMotor1.DMOV && realMotor2.DMOV && doneMovingGate_
as suggested by Tim
(http://www.aps.anl.gov/epics/tech-talk/2008/msg00127.php). I think it
would be worth to compare my implementation with Tim's probably a bit
more thoroughly tested one.
Martin
motor record: soft motor & DMOV Konrad, Martin
RE: motor record: soft motor & DMOV Mooney, Tim M.
Re: motor record: soft motor & DMOV Konrad, Martin
Prev: RE: Hardware simulator Emmanuel Mayssat
Next: RE: Hardware simulator Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: motor record: soft motor & DMOV Kevin Peterson
Next: Re: motor record: soft motor & DMOV Konrad, Martin
