1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Build problem of EPICS R3.14.12.3 for ARM processor in Linux
To: Jim Chen <[email protected]>
Cc: "'EPICS tech-talk'" <[email protected]>
Date: Thu, 29 Aug 2013 14:45:42 -0500
Hi Jim,
On 08/29/2013 10:18 AM, Jim Chen wrote:
make -C ./cap5 install
make[2]: Entering directory `/home/root/R3.14.12.3/base/src/cap5'
perl ../../bin/linux-arm/makeMakefile.pl O.linux-arm ../../..
mkdir O.Common
make -C O.linux-arm -f ../Makefile TOP=../../.. T_A=linux-arm install
make[3]: Entering directory `/home/root/R3.14.12.3/base/src/cap5/O.linux-arm'
rm -f Cap5.c Cap5.c_new
perl /usr/lib/perl/5.14.2/ExtUtils/xsubpp -typemap /usr/lib/perl/5.14.2/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
Can't open perl script "/usr/lib/perl/5.14.2/ExtUtils/xsubpp": No such file or directory
Martin Konrad's point about a missing Perl package is right, this script normally comes with the standard Perl distribution but many Linux distributions have taken to splitting up Perl into multiple packages and only installing some of them by default.
However unless you are planning to make use of the Perl CA library on this system you can ignore this error, it is only needed to let Perl programs talk to the Channel Access client library. The src/cap5 subdirectory is the last one that gets built in base 3.14 so your installation should be fully working apart from the Perl bindings to CA.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
RE: Build problem of EPICS R3.14.12.3 for ARM processor in Linux Jim Chen
Ipac driver 2.12 now available Andrew Johnson
Prev: Re: motor record: soft motor & DMOV Konrad, Martin
Next: Re: Hardware simulator Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Build problem of EPICS R3.14.12.3 for ARM processor in Linux Jim Chen
Next: RE: Build problem of EPICS R3.14.12.3 for ARM processor in Linux Jim Chen
