Thanks for all the reply. As Andrew said, EPICS does work since I don't use Perl CA Library.
I will try to get the module for xsubpp and need more tests.
Thanks again.
Jim
> -----Original Message-----
> From: Andrew Johnson [mailto:[email protected]]
> Sent: 29 August 2013 20:46
> To: Jim Chen
> Cc: 'EPICS tech-talk'
> Subject: Re: Build problem of EPICS R3.14.12.3 for ARM processor in Linux
> Hi Jim,
> On 08/29/2013 10:18 AM, Jim Chen wrote:
> > make -C ./cap5 install
> > make[2]: Entering directory `/home/root/R3.14.12.3/base/src/cap5'
> > perl ../../bin/linux-arm/makeMakefile.pl O.linux-arm ../../..
> > mkdir O.Common
> > make -C O.linux-arm -f ../Makefile TOP=../../.. T_A=linux-arm install
> > make[3]: Entering directory
> `/home/root/R3.14.12.3/base/src/cap5/O.linux-arm'
> > rm -f Cap5.c Cap5.c_new
> > perl /usr/lib/perl/5.14.2/ExtUtils/xsubpp -typemap
> > /usr/lib/perl/5.14.2/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv
> > Cap5.c_new Cap5.c Can't open perl script
> > "/usr/lib/perl/5.14.2/ExtUtils/xsubpp": No such file or directory
> Martin Konrad's point about a missing Perl package is right, this script
> normally comes with the standard Perl distribution but many Linux
> distributions have taken to splitting up Perl into multiple packages and only
> installing some of them by default.
> However unless you are planning to make use of the Perl CA library on this
> system you can ignore this error, it is only needed to let Perl programs talk to
> the Channel Access client library. The src/cap5 subdirectory is the last one
> that gets built in base 3.14 so your installation should be fully working apart
> from the Perl bindings to CA.
> - Andrew
> Advertising may be described as the science of arresting the human
> intelligence long enough to get money from it. -- Stephen Leacock
- Ipac driver 2.12 now available Andrew Johnson
- Build problem of EPICS R3.14.12.3 for ARM processor in Linux Jim Chen
- Re: Build problem of EPICS R3.14.12.3 for ARM processor in Linux Andrew Johnson
RE: Hardware simulator austen.rose
Registration for Fall Collaboration Meeting Is Open Again Shoaee, Hamid
<2013>
2025
2026
Re: Build problem of EPICS R3.14.12.3 for ARM processor in Linux Konrad, Martin
<2013>
2025
2026
