1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Motor field "UEIP" cause
To: 汪启胜 <[email protected]>
Cc: [email protected]
Date: Tue, 3 Sep 2013 10:41:33 -0500
Hello Qisheng,
With regard to the "***MAXv card #Disabled*** Watchdog Timeout CTR =" error message,
I posted this message to tech-talk describing the problem.
What is the serial # of your MAXv board?
Ron
On 8/31/2013 4:02 AM, 汪启胜 wrote:
Dear all,
I have a similar behavior as the thread http://www.aps.anl.gov/epics/tech-talk/2010/msg00906.php which posted at 2010. But it occurs when I change the field UEIP anytime. At first, I wrote the UEIP in the motor template, the message “drvMAXv.cc:motorIsr: command error ? card 00” will cause the ioc initialize failed. After remove the field in the db field, the ioc can be loaded successfully and running without problem. But I have encoder, so when I set UEIP to Yes or No, the message come out in console, while the ioc do not crash, and the encoder works also.
By the way, I also saw the timing problem when ioc boot, I got the message like "***MAXv card #Disabled*** Watchdog Timeout CTR ="
The controller is a mvme5500 running with vxworks, Tornado 2.6. The version of motor is 6-7-1. Any suggestion to remove these messages is appreciated.
Best Regards,
Qisheng
RE: Motor field "UEIP" cause austen.rose
Motor field "UEIP" cause 汪启胜
Prev: Re: Serious issue with JCA / CAJ Ralph Lange
Next: RE: Motor field "UEIP" cause austen.rose
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Motor field "UEIP" cause 汪启胜
