1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Motor field "UEIP" cause
To: <[email protected]>, <[email protected]>
Cc: [email protected]
Date: Tue, 3 Sep 2013 16:08:48 +0000
All,
With reference to the MAXv card #Disabled message, I was in contact with Prodex a little while ago, and they introduced a bug in single axis mode thus:
I can confirm that in your FW1.42 the #WS does not work in single axis mode. It still works in AA/AM mode.
This was unintentional and we will provide a fix shortly.
It was fixed in 1.43.
Austen Rose
Senior Software Engineer
+44 (0)1235 77(8495)
Diamond Light Source Ltd
Diamond House
Harwell Science and Innovation Campus
Didcot
Oxfordshire OX11 0DE
United Kingdom
From: [email protected] [mailto:[email protected]] On Behalf Of Ron Sluiter
Sent: 03 September 2013 16:42
To:
汪启胜
Subject: Re: Motor field "UEIP" cause
Hello Qisheng,
With regard to the "***MAXv card #Disabled*** Watchdog Timeout CTR =" error message,
I posted this message to tech-talk describing the problem.
What is the serial # of your MAXv board?
Ron
On 8/31/2013 4:02 AM, 汪启胜 wrote:
Dear all,
I have a similar behavior as the thread http://www.aps.anl.gov/epics/tech-talk/2010/msg00906.php which posted at 2010. But it occurs when I change the field UEIP anytime. At first, I wrote the UEIP in the motor template, the message “drvMAXv.cc:motorIsr: command error ? card 00” will cause the ioc initialize failed. After remove the field in the db field, the ioc can be loaded successfully and running without problem. But I have encoder, so when I set UEIP to Yes or No, the message come out in console, while the ioc do not crash, and the encoder works also.
By the way, I also saw the timing problem when ioc boot, I got the message like "***MAXv card #Disabled*** Watchdog Timeout CTR ="
The controller is a mvme5500 running with vxworks, Tornado 2.6. The version of motor is 6-7-1. Any suggestion to remove these messages is appreciated.
Best Regards,
Qisheng
Motor field "UEIP" cause 汪启胜
Re: Motor field "UEIP" cause Ron Sluiter
Prev: Re: Motor field "UEIP" cause Ron Sluiter
Next: Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Vacancy at Diamond Light Source for Accelerator Control Systems Leader mark.heron
