1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PMAC VME card base address issue
Date: Thu, 5 Sep 2013 23:01:18 +0000
Hi Chen,
I usually work with the PMAC i-variables rather than writing directly to memory (just slightly less obscure!).
The ones I would check are I90..I99 - just to double check your memory writes worked as you expected.  Also if you post the values of those here it might be easier for someone to help you.
In particular, check I93 and I94 (VME mailbox base address) - in your case looks like they should be $80 and $7F respectively.
Also double check that the PMAC is really properly inserted into the VME crate, if it is not seated well that can cause problems too.
Good luck!
Emma
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Chen Xue
> Sent: Friday, 6 September 2013 2:25 AM
> To: [email protected]
> Subject: PMAC VME card base address issue
> Hi, there,
> We have Delta Tau PMAC VME Motion Controller. When I replaced some of
> our malfunction PMAC VME cards, I have a base address issue.
> I did the following commands to set up replacement PMAC's VME base
> address and communication. The designated base address is 0x807FA200
> and DPRAM address is 0x80704000.
> WX$0783,$09,$04,$80,$7F,$A2,$02,$A5,$70,$E0,$80
> SAVE
> Then I restored configuration file to PMAC's VME and rebooted its IOC.
> The error message is below.
> pmacVmeConfig (1, 0x807FA200, 0x80704000, 0xa5, 2)
> pmacVmeConfig: Failure probing for base address. value = -1 =
> 0xffffffff = _clientQ + 0xff051efb
> Could someone help me?
> Thank you,
> Chen
PMAC VME card base address issue Chen Xue
Prev: RE: seq and synchronous writes Mooney, Tim M.
Next: Re: seq and synchronous writes Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: PMAC VME card base address issue Chen Xue
Next: RE: PMAC VME card base address issue Emma Shepherd
