1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PMAC VME card base address issue
To: Chen Xue <[email protected]>
Date: Mon, 9 Sep 2013 00:00:21 +0000
Hi Chen,
That's very strange!  How are you checking the variables, using PeWin PRO?
Have you tried re-inserting the card into the crate?
Cheers,
Emma
> -----Original Message-----
> From: Chen Xue [mailto:[email protected]]
> Sent: Friday, 6 September 2013 11:54 PM
> To: Emma Shepherd
> Subject: Re: PMAC VME card base address issue
> Hi, Emma,
> Thank you for your reply. The weird things is all of our I90..I99 are
> the same below whether it's function or malfunction PMAC VME cards. So
> I can't count on it.
> I91=0
> I92=0
> I93=0
> I94=0
> I95=0
> I96=0
> I97=0
> I98=0
> I99=64
> Chen
> On 9/5/2013 6:00 PM, Emma Shepherd wrote:
> > Hi Chen,
> > I usually work with the PMAC i-variables rather than writing directly
> to memory (just slightly less obscure!).
> > The ones I would check are I90..I99 - just to double check your
> memory writes worked as you expected.  Also if you post the values of
> those here it might be easier for someone to help you.
> > In particular, check I93 and I94 (VME mailbox base address) - in your
> case looks like they should be $80 and $7F respectively.
> > Also double check that the PMAC is really properly inserted into the
> VME crate, if it is not seated well that can cause problems too.
> > Good luck!
> > Emma
> >> From: [email protected] [mailto:tech-talk-
> >> [email protected]] On Behalf Of Chen Xue
> >> Sent: Friday, 6 September 2013 2:25 AM
> >> To: [email protected]
> >> Subject: PMAC VME card base address issue
> >> Hi, there,
> >> We have Delta Tau PMAC VME Motion Controller. When I replaced some
> of
> >> our malfunction PMAC VME cards, I have a base address issue.
> >> I did the following commands to set up replacement PMAC's VME base
> >> address and communication. The designated base address is 0x807FA200
> >> and DPRAM address is 0x80704000.
> >> WX$0783,$09,$04,$80,$7F,$A2,$02,$A5,$70,$E0,$80
> >> SAVE
> >> Then I restored configuration file to PMAC's VME and rebooted its
> IOC.
> >> The error message is below.
> >> pmacVmeConfig (1, 0x807FA200, 0x80704000, 0xa5, 2)
> >> pmacVmeConfig: Failure probing for base address. value = -1 =
> >> 0xffffffff = _clientQ + 0xff051efb
> >> Could someone help me?
> >> Thank you,
> >> Chen
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2012.0.2242 / Virus Database: 3222/6141 - Release Date:
> 09/05/13
PMAC VME card base address issue Chen Xue
Prev: Re: Delay within asyn driver (was: epicsThread) Vikram Bhagat
Next: Use element of waveform as input to ai record Phillip Sorensen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: PMAC VME card base address issue Emma Shepherd
Next: seq and synchronous writes Konrad, Martin
