1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: seq and synchronous writes
Date: Fri, 6 Sep 2013 17:23:19 +0200
Hi Mark
sorry, my remark was wrong, or at least misleading, because I did not provide
enough context. Here are the details:
On Friday, September 06, 2013 12:57:08 you wrote:
> > BTW, using an event flag in addition to testing the value of a (assigned
> > and monitored) variable is redundant, except when you associate the event
> > flag with several distinct PVs.
> I have a basic question about this.  If I have a when statement
>     when (DMOV == 1) {
>     } state2
> When is that block executed?
> 1) Only when DMOV changes and is 1
> 2) When any event the sequencer is monitoring occurs and DMOV is 1
> I always thought the answer was 2) above,
You are absolutely right.
> so an event flag was needed to
> check if it was actually a change in DMOV that has happened.
That certainly depends on the details of your program and the underlying
database. Consider the following more complete code (which I had in mind when
writing the above); the important step I failed to mention is that you must
reset the motorDMOV variable before doing the pvPut to the motor record:
	state start {
		when (foo) {
			motorDMOV = 0;
			pvPut(motor);
		} state check
	state check {
		when(motorDMOV) {
		} state done
It is certainly true that 'state check' might be entered before the motor
record had a chance to set DMOV to zero, so if you do not reset the motorDMOV
variable the program might actually see a motorDMOV that is /still/ non-zero.
Using an event flag in addition to the value as in
	state start {
		when (foo) {
			pvPut(motor);
		} state check
	state check {
		when(efTestAndClear(ef_motorDMOV) && motorDMOV) {
		} state done
would achieve the same result.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
seq and synchronous writes Konrad, Martin
Re: seq and synchronous writes Benjamin Franksen
RE: seq and synchronous writes Mark Rivers
Prev: RE: seq and synchronous writes Mark Rivers
Next: Re: seq and synchronous writes Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
