1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Multiple patterns/ .sub files for the same .db file
To: [email protected]
Date: Tue, 10 Sep 2013 19:06:11 +0200
Hello,
I have .sub file looking like this:
file "hvtest.db"
    pattern {PROTO, P, BOXNO, LEVELNO, CHANNELNO, ELEMENTNO}
        {hvtest.proto, HV, 19, 0, 0, 0}
        {hvtest.proto, HV, 19, 0, 1, 1}
Now I would need another pattern in the same .db file looking like this:
file "hvtest.db"
   pattern {EELO, EEUP}
        {dhcp, DHCP}
        {ip, IP}
I tried two dbLoadTemplate - lines in my .cmd file
dbLoadTemplate "a.sub"
dbLoadTemplate "b.sub"
but I then got Error messages saying the substitutions from the first file are undefined. I also tried to put both patterns in one file (I found examples with different patterns for different .db files). But then again I get error messages saying the substitutions are undefined. When I directly append the second pattern after the first, I get a syntax error message. So how can this be done?
Tito
Re: Multiple patterns/ .sub files for the same .db file Andrew Johnson
RE: Multiple patterns/ .sub files for the same .db file Emmanuel Mayssat
Prev: RE: motor record: soft motor & DMOV Mark Rivers
Next: Re: Multiple patterns/ .sub files for the same .db file Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: race condition with calcout & CA input links? Andrew Johnson
