What about changing your calcout record so that is still CP on DMOV, but it writes 1 to the output whenever DMOV is 1. Then you are not limiting yourself to transitions (which you might have missed), but you are saying "whenever DMOV changes and is 1 set the output gate".
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Konrad, Martin
Sent: Tuesday, September 10, 2013 11:45 AM
To: [email protected]; [email protected]; [email protected]; [email protected]; [email protected]
Subject: Re: motor record: soft motor & DMOV
Hello motor record maintainers,
further investigation revealed that this problem can also occur without
motor record (cf. the new thread on
http://www.aps.anl.gov/epics/tech-talk/2013/msg01898.php). BUT: The
problem with short 1-0-1 transitions could be avoided if the record
using this data is in the same lock set as the motor record. Sure I can
use NPP+FLNK to connect other records to the motor record's DMOV field.
But unfortunately it seems motor record does not trigger its forward
link after setting DMOV to 0. This makes NPP+FLNK pretty useless for
this field...
Is it possible to trigger the forward link when DMOV goes to 0 without
breaking hundreds of other applications?
From the documentation I was expecting that DLY=1 should stretch the
time of the 1-0-1 transition to 1 second. But that doesn't have any
effect if the motor does not need to be moved. Is this the intended
behavior (the documentation does not cover this special case)?
Any suggestions how to fix my problem?
Martin
- Re: motor record: soft motor & DMOV Konrad, Martin
Re: StreamDevice communication problems Tito Körner
Multiple patterns/ .sub files for the same .db file Tito Körner
<2013>
2025
2026
<2013>
2025
2026
