1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EtherCAT and NI slave chassis [SEC=UNCLASSIFIED]
To: <[email protected]>, <[email protected]>
Date: Thu, 12 Sep 2013 08:21:46 +0000
Hi Damien,
We trialled the National Instruments modules with the NI 9144 [1]
backplane that supports several compact RIO modules.
I tested it with the NI 9125 [2] and the NI 9239 [3] at 1 KHz. Even
though the modules are capable of acquiring samples faster, acquiring
them over Ethercat would mean modifying the backplane FPGA and we were
not prepared to reprogram it (it also involved purchasing more
hardware and licenses). Our Detectors group characterised the ADCs
and found them superior to Beckhoff ADCs.
Diamond's EtherCAT driver depends on XML information files that
National Instruments don't provide. They do provide a tool to generate
the xml description files and I only managed a few configurations
using product revisions as a marker for configurations.
The backplane's EPROM also has to be programmed for Etherlab to bring
up the chain, as described in Etherlab's FAQ page [4].
I have not tested any counters. Would the Ethercat update rate of 1
Khz be sufficient for your counters?
HTH,
Ronaldo
[1] NI 9144 8-Slot EtherCAT Slave Chassis for C Series I/O Modules
    http://sine.ni.com/nips/cds/view/p/lang/en/nid/206735
[2] NI 9215 4-Channel, 100 kS/s/ch, 16-bit, ±10 V Analog Input Module
    http://sine.ni.com/nips/cds/view/p/lang/en/nid/208793
[3] NI 9239 4-Channel, 24-Bit Analog Input Module
    http://sine.ni.com/nips/cds/view/p/lang/en/nid/208797
[3] I'm trying to establish communication with a slave, but the
    configuration fails. What can I do?
    http://www.etherlab.org/en/ethercat/faq.php
RE: EtherCAT and NI slave chassis [SEC=UNCLASSIFIED] LYNCH, Damien
Prev: BiRa Ethernet Power Supply Controllers Rod Nussbaumer
Next: RE: BiRa Ethernet Power Supply Controllers Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: EtherCAT and NI slave chassis [SEC=UNCLASSIFIED] LYNCH, Damien
Next: RE: EtherCAT and NI slave chassis [SEC=UNCLASSIFIED] LYNCH, Damien
