1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Read local CSS BOY PV form Java
To: Manuel Millán Álvarez <[email protected]>
Date: Mon, 16 Sep 2013 08:35:26 -0400
Hi:
Local PVs cannot be read by an external application.
Access to local PVs is limited to the same CSS instance that created them.
In the latest incarnation, closing a CSS *.opi that uses "loc://pv" will actually release that "loc://pv" and the underlying pvmanager will delete it, so the next time you open that same *.opi, you start over with a new variable.
If you want to have PVs that last longer, or are network accessible (including localhost), use an EPICS soft IOC.
-Kay
On Sep 16, 2013, at 7:04 AM, Manuel Millán Álvarez <[email protected]<mailto:[email protected]>> wrote:
Good Morning
I am developing a simulation system with CSS boy. I want to read/write data values from loc PVs by using an external application.
I have a CSS boy simulation application running in a local computer. This application has an element with PV name: loc://testElement1.  I have another application (written in Java with JCA-CAJ) and I want to read the PV values from this application.
Is it possible?
I think this is not possible, (I can do it using a pre-defined PV element in EPICS) but I am not sure if I can read/write values from loc PV from a program out of the .opi class.
Thank you.
Manuel Millán
Área de Ejecución
Intelligent Integration Factory S.L.
Parque Científico Tecnológico de Huelva, E2000
Pol. Industrial La Raya, Calle Caucho nº1,
21.110, Aljaraque  (Huelva)
Tel: +34 959 100 389 / +34 615 176 633
www.i2factory.com<http://www.i2factory.com/>
[https://lh3.googleusercontent.com/OU9lDZtzM4ZCM82HS_xd6h11sLwEQhzF53KUzfV1qtzWrCNUdYgfn0y7BGmund4XU2zAnzGos_Jfwtis5bLE3-DRoEmV81HukO1NwcUpNmXfmoJGKfc]<http://www.i2factory.com/>
Read local CSS BOY PV form Java Manuel Millán Álvarez
Prev: Re: RDB Archiver setup Kasemir, Kay
Next: EPICS-R3.14.12 installation on Ubuntu-12.04-LTS x86 PC Keith Parker
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Read local CSS BOY PV form Java Manuel Millán Álvarez
