Hi:
Where are your IOCs running? Are they all on the same Windows computer?
Your archive engine is configured to _only_ look at localhost:
> 2013-09-16 11:40:09.607 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Running, CA addr list: 127.0.0.1
Add a line like this to the engine's config:
org.csstudio.platform.libs.epics/addr_list=127.0.0.1 some_other_ip some_network_broadcast_ip
See "Hierarchical Preferences" in http://cs-studio.sourceforge.net/docbook/pt01.html about the "-pluginCustomization" option to provide such settings.
Kay
On Sep 16, 2013, at 6:02 AM, Vítek Michal <[email protected]> wrote:
> I am trying to use EPICS RDB archiver on Windows 7. So far I manage to prepare Configuration tool and Engine products. I have configured DB scheme “archiver“ (just for 2 PVs for now) and started the engine. Everything goes well, but the archiver does not connect to the EPICS PVs (I can see Read timeout error in the log and it is also stated by the webserver.). Does somebody have any idea what needs to be configured to enable the connection to the EPICS PVs ? I have tryed to turn off the firewalls to be sure the communication is not blocked.
> I will be thankfull for any advice.
> Cheers,
> Mike
> The log from the startup is:
> c:\data\ELI Products\L1_BEAUTY_Archiver\eclipse>ArchiveEngine.exe -engine l1 -pluginCustomization l1b.ini
> 2013-09-16 11:40:08.975 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Archive Engine 3.2.0.201309141337
> 2013-09-16 11:40:09.104 INFO [Thread 1] org.csstudio.archive.engine.server.EngineServer (<init>) - Engine HTTP Server on http://localhost:4812/main
> 2013-09-16 11:40:09.104 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Reading configuration 'l1'
> 2013-09-16 11:40:09.556 CONFIG [Thread 1] org.csstudio.utility.pvmanager.epics.Epics3DataSource (<clinit>) - Loading epics data source parameters: com.cosylab.epics.caj.CAJContext - 2
> 2013-09-16 11:40:09.598 CONFIG [Thread 1] org.csstudio.utility.pvmanager.Activator (start) - Adding data source ca
> 2013-09-16 11:40:09.598 CONFIG [Thread 1] org.csstudio.utility.pvmanager.Activator (start) - Adding data source sim
> 2013-09-16 11:40:09.599 CONFIG [Thread 1] org.csstudio.utility.pvmanager.Activator (start) - Adding data source epics
> 2013-09-16 11:40:09.600 CONFIG [Thread 1] org.csstudio.utility.pvmanager.Activator (start) - Setting default data source to ca
> 2013-09-16 11:40:09.607 INFO [Thread 1] org.csstudio.archive.engine.Application (start) - Read configuration: 2 channels in 0.501 seconds
> 2013-09-16 11:40:09.608 INFO [Thread 1] org.csstudio.archive.engine.model.WriteThread (start) - Adjusting write period from 3 to 5
> 2013-09-16 11:40:09.610 INFO [Thread 27] org.csstudio.archive.engine.model.WriteThread (run) - WriteThread starts
> 2013-09-16 11:40:09.638 INFO [Thread 31] org.csstudio.archive.engine.scanner.ScanThread (run) - Scan Thread runs
- RDB Archiver setup Vítek Michal
Read local CSS BOY PV form Java Manuel Millán Álvarez
Re: Read local CSS BOY PV form Java Kasemir, Kay
<2013>
2025
2026
Re: RDB Archiver setup Jack
<2013>
2025
2026
