Hi:
The issue was simply a custom-build archive engine that didn't include the PVManager support for EPICS.
The ArchiveEngine.product lists these dependencies, amongst others: pvmanager, pvmanager.epics, pvmanager.sim, …
If you build an archive engine without pvmanager.epics, in fact no data sources at all, you get the error message
> …. uses the default data source but one was never set.
-Kay
On Sep 17, 2013, at 1:00 AM, "Konrad, Martin" <[email protected]> wrote:
> Hi,
>> java.lang.IllegalArgumentException: Channel emcvme100_fanspd1 uses
> Try using "epics://pvname" instead of "pvname". Maybe one of the CSS
> developers can give you a hint why epics is not the default (it usually
> should be).
> Martin
- Re: RDB archive engine warning messages Konrad, Martin
RE: A little bit of history: Life before and after EPICS... Paul.gibbons
RE: asyn support for EPICS timestamps and records with TSE=epicsTimeEventDeviceTime Mark Rivers
<2013>
2025
2026
A little bit of history: Life before and after EPICS... Emmanuel Mayssat
<2013>
2025
2026
