1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn support for EPICS timestamps and records with TSE=epicsTimeEventDeviceTime
Date: Tue, 17 Sep 2013 12:30:16 -0400
Hi Mark,
Thanks. I was trying to figure out if the areaDetector API is backwards compatible (regardless of what TSE is set to). But it does seem to be from reading your document. If a detector driver doesn't call updateTimeStamp(&pImage->epicsTS), then it will just be a zero timestamp presumably (and the record timestamp will be set to zero if TSE=-2). So, it would be harmless, but probably not something that people will do.
Cheers,
Matt
On Sep 17, 2013, at 10:29 AM, Mark Rivers <[email protected]> wrote:
> Hi Matt,
>> In the future plans section at the end, you mentioned that all plugins will call setTimeStamp to set the plugin timestamp.
>> Will this be required, even if TSE!=-2? Or, if it is required, would it done automatically in the plugin base class?
> It is required even if TSE!=-2, because the plugin has no way of knowing what TSE is.
> However, it is automatically handled by the plugin base class.
> I have now finished the areaDetector task I discussed under the Future Plans section in the original document.  I have also changed the asyn implementation by adding two new asyn shell commands.
> I have attached the revised document for asyn, and the new document for areaDetector.
> I would appreciate any comments before I release these in the next versions of asyn and areaDetector.
> Thanks,
> Mark
> -----Original Message-----
> From: Pearson, Matthew R. [mailto:[email protected]]
> Sent: Tuesday, September 17, 2013 8:25 AM
> To: Mark Rivers
> Hi Mark,
> I read your document, and it seems like a useful addition.
> In the future plans section at the end, you mentioned that all plugins will call setTimeStamp to set the plugin timestamp. Will this be required, even if TSE!=-2? Or, if it is required, would it done automatically in the plugin base class?
> Cheers,
> Matt
> On Sep 11, 2013, at 4:46 PM, Mark Rivers <[email protected]> wrote:
>> <AsynTimeStampSupport.pdf>
> <AsynTimeStampSupport.pdf><areaDetectorTimeStampSupport.pdf>
RE: asyn support for EPICS timestamps and records with TSE=epicsTimeEventDeviceTime Mark Rivers
Prev: RE: asyn support for EPICS timestamps and records with TSE=epicsTimeEventDeviceTime Mark Rivers
Next: RE: asyn support for EPICS timestamps and records with TSE=epicsTimeEventDeviceTime Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
