1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cleaning up at exit and waiting threads
To: <[email protected]>
Date: Wed, 25 Sep 2013 20:24:00 +0200
Am Mittwoch, 25. September 2013, 06:50:18 schrieb Eric Norum:
> I think that it's not a bug.   It's more a 'least common denominator'
> issue with the assorted platforms on which EPICS runs. My approach
> has been to add a 'pleaseTerminate' event to the device private
> structure then place a check for this event right after the 'wait for
> work' event in the worker thread.  Shutdown requests first set the
> pleaseTerminate event and then the normal check-for-work event.
I am using that approach, too, at least when I (have to) use semaphores
directly. Whenever possible I use message queues nowadays, and I type
the messages using a tagged union, just as I would with an algebraic
datatype in Haskell. So I have
enum msgTag {
	MSG_DO_X,
	MSG_DO_Y,
	/* ... more message types */
and the type of messages is
union msg {
	enum msgTag tag;
	/* ... extra data common to all messages */
	struct
		/* ... whatever extra data is needed to do x */
	} do_x;
	struct
		/* ... whatever extra data is needed to do y */
	} do_y;
	/* ... etc */
I even write data constructor functions, one for each message type, e.g.
__inline__ msg_do_x(/*...data needed for a message of this type */) {
	/* assign the struct members here */
so I cannot forget to initialize a member. On the receiving end I use a
switch statement. In this way I can offload routine checks to the C type
checker, which makes the program much more robust against changes such
as adding a new message type. Which brings me back to the topic at hand,
since shutdown is now just another message type:
enum msgTag {
	MSG_SHUTDOWN /* normally needs no extra data */
I find it much easier to reason about my code if it is structured in
this way.
Cheers
Ben
> On Sep 25, 2013, at 6:15 AM, Dirk Zimoch <[email protected]> wrote:
> > Hi folks,
> > Today I did some tests regarding "clean" shutdown of an IOC and
> > found some unsatisfying results. There seems to be no clean way of
> > destroying events, mutexes, or message queues, because they all
> > cannot be destroyed as long as there are threads waiting on them.
> > At least that is the case on Linux.
> > Example: One thread is waiting on an event. Whenever it gets
> > signaled, it does some work on hardware.
> > At exit I have do shutdown the hardware cleanly. After this time no
> > thread must try to use it any more. Also I better don't simply kill
> > the work thread while it is accessing the hardware. (And I probably
> > do not know all the threads involved). So I prefer to terminate
> > while the thread has noting to do, i.e. while it is waiting on the
> > event.
> > I had expected that when I destroy the queue, all pending threads
> > would wake up and receive an error. This is not the case. Instead I
> > found that destroying the event failed with "Device or resource
> > busy"
> > The same is true for mutexes as I tested. Also message queues cannot
> > be released like this.
> > Is this a bug or simply "unsupported"?
> > Any idea what I can do?
> > Dirk
"Make it so they have to reboot after every typo." -- Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: cleaning up at exit and waiting threads Dirk Zimoch
Re: cleaning up at exit and waiting threads Eric Norum
Prev: sequencer release 2.1.14 Benjamin Franksen
Next: Re: Generating a loadable module for cexp (epics 3.14.12.3) Sue Witherspoon
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: cleaning up at exit and waiting threads Eric Norum
Next: Re: cleaning up at exit and waiting threads Dirk Zimoch
