1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: MEDM -cmap Switch
Cc: "Poff, Mark A" <[email protected]>
Date: Fri, 27 Sep 2013 15:31:26 +0000
Hello all,
I’m having difficulty understanding the utility of the MEDM “-cmap” switch.  The MEDM Reference Manual tells me how to change the default MEDM palette in siteSpecific.h, and how to edit the “display” block of a display to make it use the palette defined in another .adl file - those things I understand.  But the manual also says to start MEDM with the -cmap option to “...use a private X colormap to circumvent the problem of not having enough colors available in the colormap”.  What does that mean?  I placed a full-spectrum colorwheel gif image on a MEDM display and to me, it appears the same regardless of whether the cmap switch is used or not.  Can someone explain, in simple terms, what cmap provides and when it might be useful?
Mark Poff
Re: MEDM -cmap Switch Andrew Johnson
Prev: Re: EPICS base Installation Error- Need Help Pearson, Matthew R.
Next: Re: agenda for the EPICS users' meeting pthomas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Strange warning from asSetFilename Dirk Zimoch
Next: Re: MEDM -cmap Switch Andrew Johnson
