1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MEDM -cmap Switch
To: "Poff, Mark A" <[email protected]>
Date: Fri, 27 Sep 2013 12:44:12 -0500
Hi Mark,
On 09/27/2013 10:31 AM, Poff, Mark A wrote:
I’m having difficulty understanding the utility of the MEDM “-cmap”
switch.  The MEDM Reference Manual tells me how to change the default
MEDM palette in siteSpecific.h, and how to edit the “display” block of a
display to make it use the palette defined in another .adl file - those
things I understand.  But the manual also says to start MEDM with the
-cmap option to “.../use a private X colormap to circumvent the problem
of not having enough colors available in the colormap/”.  What does that
mean?  I placed a full-spectrum colorwheel gif image on a MEDM display
and to me, it appears the same regardless of whether the cmap switch is
used or not.  Can someone explain, in simple terms, what cmap provides
and when it might be useful?
I think it is only useful if you have a very old video card that has a limited colormap. Early colour displays only had enough RAM to store 8 bits per displayed pixel, thus you could only have 256 colours on the screen at a time and the display driver programmed the colormap to tell hardware what RGB value to emit for each of the 256 possible pixel values it read from the frame-buffer.
The X server managed its own colormap settings and allocated colours to the running programs on request, but it also allowed programs to define their own private colormap which it would switch to when the focus belonged to that program. This resulted in other windows looking really weird, but the foreground program's colours always looked right.
More details at http://tronche.com/gui/x/xlib/color/
TL;DR version: The -cmap option is not useful on modern video displays.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
MEDM -cmap Switch Poff, Mark A
Prev: Re: Strange warning from asSetFilename Andrew Johnson
Next: procServ and sseq Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MEDM -cmap Switch Poff, Mark A
