I have several soft IOCs running on different ports on a linux PC
and several IOCs running on VME crates.
I'm using 3.14.11 and SL5.4.
When running one soft IOC from a command line, I can run sequences
that set values in the VME IOCs.
However, when I've started the IOC from procServ, my sequences fail
to change the values of the PVs
in the VME IOCs. I did try the trick of using a pre_st.cmd file to
ensure that EPICS_CA_ADDR_LIST is
properly defined.
I cannot find this problem in the archives. Any help would be
greatly appreciated.
Pierrick
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
Re: MEDM -cmap Switch Andrew Johnson
RE: procServ and sseq Hartman, Steven M.
<2013>
2025
2026
<2013>
2025
2026
ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
