Hi Steven,
That's an interesting point. In both cases where this fails, the
VME IOCs get initialized by epics (username),
but all of them are loaded from /home/controls. My soft IOCs are
all from epics.
I had a similar problem with things like the channel archiver. My
/etc/rc.local never worked to start the
archiver because the archiver was built in /home/archiver and the
user was epics.
I'll let you know (for the techtalk record) when I try again.
Pierrick
On 09/28/2013 02:07 PM, Hartman, Steven
M. wrote:
Is the Linux IOC running under the same user ID when using procServ as when running from the command line? If not, access security may be blocking writes.
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
_______________________________________________________________
Pierrick Hanlet
IIT/Fermilab
+44-(0)1235-44-5550 (RAL)
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-(0)79-48-860-197 (US/UK mobile)
- RE: procServ and sseq Hartman, Steven M.
A question regarding sequencer compatibility Benjamin Franksen
<2013>
2025
2026
<2013>
2025
2026
ANJ, 20 Apr 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
