1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: A question regarding sequencer compatibility
To: <[email protected]>
Date: Sun, 29 Sep 2013 03:31:02 +0200
Hi Everyone
until now I have tried hard to avoid breaking existing SNL programs when
developing new features or cleaning up the code base. I cannot claim
that I succeeded completely, but I got the impression that the
transition from 2.0 to 2.1 went reasonably well for most people.
I am planning to make some changes for version 2.2 that can break
existing programs if they rely on certain mis-features that I inherited
from earlier versions.
One of these is the behaviour of pvPut and pvGet with multi-PV arrays.
Concretely, assume a declaration
	int x[2];
	assign x to { "pv1", "pv1" };
and an action statement
	pvGet(x);
Currently this is equivalent to
	pvGet(x[0]);
I find this quite un-intuitive and arbitrary. My current plan is to
change the behaviour so that if an array has been assigned to multiple
PVs, the pv functions should act on *all* elements, instead of only the
first.
You might think at first that this is unnecessary, why not implement the
behaviour with a simple loop:
	for(i=0; i<2; i++)
		pvGet(x[i]);
But this would have far greater latency than necessary, since it issues
one request, waits for the response, then issues the next request, waits
again, etc. An implementation in the runtime system could easily issue
all requests up front, then simultaneously wait for the responses. If
you want to do this in SNL code, it would have to look like
	for(i=0; i<2; i++)
		pvGet(x[i],ASYNC);
	/* ... switch to a new state, then:*/
	when (pvGetComplete(x[0]) && pvGetComplete(x[1])) {
		/* continue ... */
which is no longer a simple loop; the code would become quite unwieldy,
especially with more array elements.
An alternative would be to instead disallow pvGet(x) for multi-PV arrays
(the compiler can detect this statically). This would mean you *have* to
say
	pvGet(x[0]);
if that is what you want to happen. I could then add new functions
(pvGets? pvGetMultiple? pvGetMany? pvGetArray?) that will behave in the
new way.
Similar considerations apply to other pv functions. As a side-note,
pvPutComplete (but *not* pvGetComplete) already supports multi-PV arrays
in a sensible way.
Comments or suggestions, especially from "sequencer power users" would
be very much appreciated.
Cheers
Ben
"Make it so they have to reboot after every typo." -- Scott Adams
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: A question regarding sequencer compatibility Benjamin Franksen
Prev: Re: procServ and sseq Pierrick Hanlet
Next: Re: Strange warning from asSetFilename Michael Abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: A question regarding sequencer compatibility Benjamin Franksen
