1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: how to issue a shell command from EPICS record ?
To: Christian Pauly <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 1 Oct 2013 23:19:58 +0000
Normally, you would do this in a client, such as a python script, that monitors the scan and starts the necessary scripts.
Sent from my Samsung Galaxy Note® II
-------- Original message --------
Date: 2013/10/01 5:59 PM (GMT-06:00)
To: EPICS Tech Talk <[email protected]>
Subject: how to issue a shell command from EPICS record ?
Hi
Hope someone has a good advice for me:
I implemented an XY-scanning table control using EPICS to handle an XY
step-motor table.
I use sscan records to implement automatic scans in x and xy-direction.
So far this works fine.
Now i want to add one more thing: Before the scan starts, i have to
start the DAQ system with a certain BASH shell-script, after the scan i
have to stop the DAQ with another shell script.
Can i somehow issue these shell-commands automatically before and after
the scan ?
Is there some record type available which can do this ???
I have been quite some time now, but could not find anything.
Any advice ?
best regards,
Christian
how to issue a shell command from EPICS record ? Christian Pauly
Prev: RE: A little bit of history: Life before and after EPICS... Emmanuel Mayssat
Next: Re: agenda for the EPICS users' meeting Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: how to issue a shell command from EPICS record ? Christian Pauly
Next: RE: how to issue a shell command from EPICS record ? Emmanuel Mayssat
