1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: how to issue a shell command from EPICS record ?
To: Christian Pauly <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 1 Oct 2013 16:28:28 -0700
StreamDevice can do that.
You will have to write iocsh function, which you can call from StreamDevice.
That iocsh function (programmed in C/C++) will call the system C-function with your script as an argument.
Note that to use StreamDevice, you don't need a physical device (i.e. your protocol can just call your function)
int dmc2183_escapeToShell(const char *p_command) {
  int status;
  status=system(p_command);
  switch(status) {
    case ERROR:
       printf("[ERROR] %s\n", p_command);
       break;
    case SUCCESS:
       funcLog(7, __FILE__ "[%d] SUCCESS\n", __LINE__);
       break;
    default:
       printf("[ERROR] status=%d\n", status);
       break;
   return(SUCCESS);
static const iocshArg dmc2183_escapeToShellArg0 = {"Command", iocshArgString};
static const iocshArg* const dmc2183_escapeToShellArgs[1] = {
  &dmc2183_escapeToShellArg0};
static const iocshFuncDef dmc2183_escapeToShellFuncDef = { "dmc2183_escapeToShell",1,dmc2183_escapeToShellArgs};
static void dmc2183_escapeToShellCallFunc(const iocshArgBuf* args) { dmc2183_escapeToShell(args[0].sval);
static void DMC2183_iocshFuncRegistrar (void) {
  iocshRegister( &dmc2183_escapeToShellFuncDef, dmc2183_escapeToShellCallFunc);
epicsExportRegistrar(DMC2183_iocshFuncRegistrar);
Enjoy,
Emmanuel
> Date: Tue, 1 Oct 2013 18:44:19 +0200
> From: [email protected]
> To: [email protected]
> Subject: how to issue a shell command from EPICS record ?
> Hi
> Hope someone has a good advice for me:
> I implemented an XY-scanning table control using EPICS to handle an XY
> step-motor table.
> I use sscan records to implement automatic scans in x and xy-direction.
> So far this works fine.
> Now i want to add one more thing: Before the scan starts, i have to
> start the DAQ system with a certain BASH shell-script, after the scan i
> have to stop the DAQ with another shell script.
> Can i somehow issue these shell-commands automatically before and after
> the scan ?
> Is there some record type available which can do this ???
> I have been quite some time now, but could not find anything.
> Any advice ?
> best regards,
> Christian
how to issue a shell command from EPICS record ? Christian Pauly
Prev: Re: agenda for the EPICS users' meeting Johnson, Andrew N.
Next: Re: how to issue a shell command from EPICS record ? Johnson, Andrew N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: how to issue a shell command from EPICS record ? Jemian, Pete R.
