Am Dienstag, 1. Oktober 2013, 17:06:16 schrieb Mooney, Tim M.:
> I'm fine with all your plans. Personally, I would also be ok with
> just changing pvXXX so that they work as one would expect them to
> work - as pvXXXs would work. Did you consider and reject a
> compile-time switch that would make pvXXX behave as pvXXXs? That
> seems simpler to me.
Thanks Tim,
I haven't considered it yet. Out of reflex, probably, I usually try to
avoid adding compiler switches if possible. In this case it doesn't
sound too bad, actually. Have to think about it, thanks for the
suggestion.
Cheers
Ben
signature.asc
Description: This is a digitally signed message part.
- A question regarding sequencer compatibility Benjamin Franksen
- RE: A question regarding sequencer compatibility Mark Rivers
- RE: A question regarding sequencer compatibility Mooney, Tim M.
Re: how to issue a shell command from EPICS record ? Johnson, Andrew N.
Re: A question regarding sequencer compatibility Benjamin Franksen
<2013>
2025
2026
Re: A question regarding sequencer compatibility J. Lewis Muir
<2013>
2025
2026
