1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: how to issue a shell command from EPICS record ?
To: Christian Pauly <[email protected]>
Date: Mon, 7 Oct 2013 16:27:31 -0700
On Oct 7, 2013, at 4:00 PM, Christian Pauly <[email protected]> wrote:
> Dear all
> thanks for all the nice suggestions how to solve my shell command problem.
> Of all presented solutions i like the "subroutine record" or the "StreamDevice" solution most.
> In both cases i have to implement a new iocsh function in C to do the system() call, as shown in the example from Emmanuel.
> My iocsh does not support the system command (solution from Dirk), always says "command not found" if i try to type it in directly in the iocsh. I found something that i have to add "registrar(iocshSystemCommand)" to my database definition file (.dbd) to get the system command in iocsh, but somehow that does not work.
Did you include "system.dbd" in  your application?
The system iocsh command is provided only when requested.
> However, if i understand correctly: If i add a new command to the iocsh which then calls the C-function system(), then i anyway dont depend on the system command in iocsh right ?
> My problem now:
> There was a nice example code posted by Emanuel, but i am quite a newby to EPICS and somehow dont figure out where to put this.
> My starting point is the example ioc application from the "EPICS Application Developers Guide" generated with the makeBaseApp.pl script.
> I can start the ioc (st.cmd), and can access the PVs using caget.
> Where do i have to put the C-code with the definition of the new iocsh command now ?
> Do i have to change Makefiles somewhere to compile it ?
> And how do i define the corresponding "subroutine record" in my database .db file ?
> Could you provide a bit more (basic) information ?
> I am using EPICS R3.14.12.3
Eric Norum
[email protected]
Re: how to issue a shell command from EPICS record ? Konrad, Martin
Re: how to issue a shell command from EPICS record ? Pavel Maslov
Re: how to issue a shell command from EPICS record ? Christian Pauly
Prev: Re: how to issue a shell command from EPICS record ? Christian Pauly
Next: Positions at Brookhaven National Lab Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: how to issue a shell command from EPICS record ? Christian Pauly
