1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: how to issue a shell command from EPICS record ?
To: Dirk Zimoch <[email protected]>
Date: Tue, 08 Oct 2013 18:05:21 +0200
Dear all, dear Dirk
now i also got the solution based on StreamDevice somehow running, and this looks pretty good. However, i am now fighting some other stupid problem related to record linking:
In my .db -file, i have the following two records:
record(stringout, "$(P):$(R):filename")
    field(DESC, "data file name")
record(stringout, "$(P):$(R):startdaqfile")
    field(DESC, "start DAQ into FILE")
    field(OMSL, "CLOSED_LOOP")
    field(DOL,  "filename.VAL")
    field(DTYP, "stream")
    field(OUT,  "@callbash.proto callbash(STARTDAQFILE) dummy $(A)")
My .prot protocolfile looks like this:
callbash {
    exec 'system "./daqcontrol.sh \$1 %s"';
And the shellscript daqcontorl.sh like this:
#!/bin/bash
echo DAQ control
echo called with command: $1
echo filename:            $2
The first record should hold a filename of the datafile to be written, the second record launches the shell script which starts the DAQ with certain command and filename.
command "STARTDAQFILE" specifies the DAQ mode.
the second parameter is the filename to be used when starting the DAQ.
My idea was, that this filename is taken from the first db-record.
My understanding from the manual is, that if i specify "OMSL CLOSED_LOOP", then the output value is read from the given link, and not from the actual value written to the record.
But if i now do a "caput XYTABLE:startdaqfile 1" (or alternatively "caput XYTABLE:startdaqfile.PROC 1") then my shell script is called with two parameters:
"STARTDAQFILE" and the number i use in the caput command.
The filename from the first record is ignored.
Any idea what i am doing wrong ?
This is the last piece i am missing to get it running...
Re: how to issue a shell command from EPICS record ? Pearson, Matthew R.
Re: how to issue a shell command from EPICS record ? Dirk Zimoch
Re: how to issue a shell command from EPICS record ? Konrad, Martin
Re: how to issue a shell command from EPICS record ? Pavel Maslov
Re: how to issue a shell command from EPICS record ? Christian Pauly
Prev: How to Read Multiple Values using StreamDevice with array_in Yasemin Barutçu
Next: EPICS Training Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: how to issue a shell command from EPICS record ? Eric Norum
Next: Re: how to issue a shell command from EPICS record ? Pearson, Matthew R.
