1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: how to issue a shell command from EPICS record ?
To: Christian Pauly <[email protected]>
Date: Wed, 09 Oct 2013 08:50:11 +0200
On 08.10.2013 18:05, Christian Pauly wrote:
field(OMSL, "CLOSED_LOOP")
Any idea what i am doing wrong ?
This is the last piece i am missing to get it running...
It is not "CLOSED_LOOP" but "closed_loop". You should see an error message when loading the record and a caget on the OMSL field should show that it is still "supervisory".
Dirk
Re: how to issue a shell command from EPICS record ? Konrad, Martin
Re: how to issue a shell command from EPICS record ? Pavel Maslov
Re: how to issue a shell command from EPICS record ? Christian Pauly
Prev: RE: EPICS Training Zimoch Elke
Next: FW: Fatal seq_monitor: pvVarMonitorOff Janez Golob
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: how to issue a shell command from EPICS record ? Pearson, Matthew R.
Next: Re: how to issue a shell command from EPICS record ? Konrad, Martin
