1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: how to issue a shell command from EPICS record ?
To: Christian Pauly <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 8 Oct 2013 05:14:06 +0000
Hi Christian,
 > thanks for all the nice suggestions how to solve my shell command
problem.
> Of all presented solutions i like the "subroutine record" or the
> "StreamDevice" solution most.
> In both cases i have to implement a new iocsh function in C to do the
> system() call, as shown in the example from Emmanuel.
You do _not_ need any IOC shell functions to use the system() call from
a subroutine record. system() is a C function, it doesn't care about the
IOC shell. But keep in mind that record processing usually is intended
to be very fast. Starting external processes that communicate with
hardware definitely isn't. It might work for you right now but you might
run into problems later. Of course you can spawn an own thread for that
on IOC start. This thread then starts the external process when you send
it a signal. A lot of code for such a simple thing. That's why I would
prefer the streamdevice solution.
Martin
Martin Konrad
Control System Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Re: how to issue a shell command from EPICS record ? Konrad, Martin
Re: how to issue a shell command from EPICS record ? Pavel Maslov
Prev: Positions at Brookhaven National Lab Dalesio, Leo
Next: Re: Base building problem on Win7 (both MinGW and VS 2012 Express) Koponen Jukka
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: how to issue a shell command from EPICS record ? Dirk Zimoch
Next: Re: how to issue a shell command from EPICS record ? Dirk Zimoch
