Something does not seem right here, I don't understand why it is failing if nbt > 32.
Unfortunately I have no experience with VXI11, and I don't have any VXI11 devices to test with. Hopefully someone else on tech-talk can help you with this.
When the writeRead fails, what is the error return?
What do you see if you set asynTraceMask=255 in the underlying VXI11 port (L0x)?
-----Original Message-----
Sent: Friday, October 11, 2013 3:34 PM
To: Mark Rivers; [email protected]
Subject: VXI11 - GPIB
Hi Mark,
I have written a device driver for a GPIB device that is using VXI11
protocol.
The device driver is sub-classed from the asynPortDriver class.
In the st.cmd file I configure the VXI11 object as follows:
vxi11Configure( "L0x","$(ETHER)",0,0.0,"gpib0",0,0)
Then in the constructor I connect:
stat=pasynOctetSyncIO->connect( _ioPort,_addr,&_apvt,0);
finally in IO routine I call:
stat=pasynOctetSyncIO->writeRead(
_apvt,pcs,ncb,_buf,nbt,1,(size_t*)nio,&nbi,&eom);
_buf is defined as char _buf[2048]
I have discovered by trial and error that the writeRead succeeds for nbt
<= 32 and fails otherwise.
I do not understand this. I think that nbt is supposed to be the size
of the read buffer (in my case _buf) simply telling the routine, which
ultimately does the device IO, to put up to nbt bytes of data into the
read buffer. Now, it happens that in my test case the device returns
only one byte of data, that is the status byte. So, why should it fail
when I give the writeRead a ridiculously large buffer to read into?
Then what if I poke the device and it chooses to reply by sending 1024
bytes of data? Do I need to worry about that and issue the writeRead
number of times with 32 byte long read buffer until all bytes of data
are read in? Since I don't know before hand how much data will be
returned, it is not obvious to me how this could be done efficiently.
Thanks Mark,
Zen
- Re: VXI11 - GPIB Pearson, Matthew R.
- Re: VXI11 - GPIB Zenon Szalata
- VXI11 - GPIB Zenon Szalata
<2013>
2025
2026
<2013>
2025
2026
