1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VXI11 - GPIB
To: Zenon Szalata <[email protected]>
Date: Fri, 11 Oct 2013 17:17:10 -0400
Could it be that the device is actually sending back 32 bytes of data? If the input buffer size is <=32 bytes, then I think the writeRead will succeed as soon as the buffer is full. But if you define a larger buffer it will wait until the timeout before returning with the timeout error code.
Did you define end-of-stream characters using setInputEos and setOutputEos?
Cheers,
Matt
On Oct 11, 2013, at 4:58 PM, Mark Rivers <[email protected]> wrote:
> Something does not seem right here, I don't understand why it is failing if nbt > 32.
> Unfortunately I have no experience with VXI11, and I don't have any VXI11 devices to test with.  Hopefully someone else on tech-talk can help you with this.
> When the writeRead fails, what is the error return?
> What do you see if you set asynTraceMask=255 in the underlying VXI11 port (L0x)?
> Mark
> -----Original Message-----
> From: Zenon Szalata [mailto:[email protected]]
> Sent: Friday, October 11, 2013 3:34 PM
> To: Mark Rivers; [email protected]
> Subject: VXI11 - GPIB
> Hi Mark,
> I have written a device driver for a GPIB device that is using VXI11
> protocol.
> The device driver is sub-classed from the asynPortDriver class.
> In the st.cmd file I configure the VXI11 object as follows:
> vxi11Configure( "L0x","$(ETHER)",0,0.0,"gpib0",0,0)
> Then in the constructor I connect:
> stat=pasynOctetSyncIO->connect( _ioPort,_addr,&_apvt,0);
> finally in IO routine I call:
> stat=pasynOctetSyncIO->writeRead(
> _apvt,pcs,ncb,_buf,nbt,1,(size_t*)nio,&nbi,&eom);
> _buf is defined as char _buf[2048]
> I have discovered by trial and error that the writeRead succeeds for nbt
> <= 32 and fails otherwise.
> I do not understand this.  I think that nbt is supposed to be the size
> of the read buffer (in my case _buf) simply telling the routine, which
> ultimately does the device IO, to put up to nbt bytes of data into the
> read buffer.  Now, it happens that in my test case the device returns
> only one byte of data, that is the status byte. So, why should it fail
> when I give the writeRead a ridiculously large buffer to read into?
> Then what if I poke the device and it chooses to reply by sending 1024
> bytes of data?  Do I need to worry about that and issue the writeRead
> number of times with 32 byte long read buffer until all bytes of data
> are read in?  Since I don't know before hand how much data will be
> returned, it is not obvious to me how this could be done efficiently.
> Thanks Mark,
> Zen
VXI11 - GPIB Zenon Szalata
RE: VXI11 - GPIB Mark Rivers
Prev: RE: VXI11 - GPIB Mark Rivers
Next: Re: VXI11 - GPIB Zenon Szalata
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
