1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: dbGetLink with options
Date: Mon, 28 Oct 2013 10:37:02 -0700
Hi Andrew,
Thank you very much for the clarification.  I was trying to add protections against
"none existing PV", "fail to read PV" and "PV in alarm".
Best regards,
Dehong
Sent: Monday, October 28, 2013 9:39 AM
To: Zhang, Dehong
Cc: [email protected]
Subject: Re: dbGetLink with options
Hi Dehong,
On 10/26/2013 11:35 AM, Zhang, Dehong wrote:
> I am trying to fetch the value from a PV in another IOC.  I would like to get the connection
> status and alarm severity in one call.  According to the developer's guide, these can be done
> by setting the options (3.14.12), but whenever I set the options to none-zero (with the proper
> return structure), it fails.
> I did a "grep dbGetLink *" in base/***/src/rec.  It seems nobody uses options.
You are correct for that API, DB links do support options but CA links
and CONST links don't (if you pass in a non-zero pointer for poptions
they will set *poptions=0 before returning to tell you that they don't
support any option bits). In 3.15 if you try and pass a non-zero value
at *options you'll get a warning message at runtime (and the value will
be zeroed again).
> Do I need to explicitly call dbCaGetLink, and check the link status and alarm severity by
> calling dbCaIsLinkConnected and dbCaGetSevr?
I would advise against using the dbCa routines directly if you can avoid
doing so, they will lock your code into using Channel Access when future
releases may provide pvAccess links too.
For the link connection status, call dbIsLinkConnected(plink) which
returns a true/false value.
The dbGetLink() routine automatically sets the alarm condition (status
and severity) of the record that owns the link, based on the link flags
and the alarm condition of the link target. What else were you planning
to do with the that alarm information?
> By the way, dbGetLink always returns "0", even when it fails or when the link is not there.
A disconnected link is not seen as an error, the IOC code should be able
to continue despite another part of the control system being down.  The
dbGetLink() routine can return a non-zero status, but disconnection does
not cause it to do that.
Note that in 3.15 and later we have been changing the implementation of
the link code to allow additional link types to be added in the future,
although we're not at that stage yet.
HTH,
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: dbGetLink with options Andrew Johnson
dbGetLink with options Zhang, Dehong
Prev: Re: dbGetLink with options Andrew Johnson
Next: Re: dbGetLink with options Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
