Hi Dehong,
On 10/28/2013 12:37 PM, Zhang, Dehong wrote:
I was trying to add protections against
"none existing PV",
You can't actually detect that, all you really know is that the PV is or
is not connected, which might be for many possible reasons.
"fail to read PV"
Your record will automatically be put into LINK_ALARM state with an
INVALID severity if there was a problem with the link communications
mechanisms.
"PV in alarm".
If the link has an MS flag, it will cause your record to go into a
LINK_ALARM with the severity copied from the link target. You might
also want to look at the MSS and MSI flags which can change that
behaviour slightly; they were added in 3.14.11.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- dbGetLink with options Zhang, Dehong
- Re: dbGetLink with options Andrew Johnson
- RE: dbGetLink with options Zhang, Dehong
Re: sequencer + streamdevice Andrew Johnson
<2013>
2025
2026
sequencer + streamdevice Christoph Burandt
<2013>
2025
2026
