1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sequencer + streamdevice
To: Christoph Burandt <[email protected]>
Cc: [email protected]
Date: Mon, 28 Oct 2013 14:20:37 -0500
Hi Christoph,
Check that the DBD file for your combined IOC contains a registrar entry for your sequence program (in the makeBaseApp example that is this line:
    registrar(sncExampleRegistrar)
This is what causes the sequencer to be included in the IOC executable and the seq command to be registered when the startup script runs.
HTH,
- Andrew
On 10/28/2013 08:07 AM, Christoph Burandt wrote:
Hello,
I'm having trouble setting up an IOC which provides both, the sequencer
and the streamdevice support at the same time.
Using "makeBaseApp -t ioc" allowed me to setup basic IOCs that support
either the sequencer or the StreamDevice support. I therefore modified
the files
configure/RELEASE
iocApp/src/Makefile
accordingly.
I checked that the resulting IOCs are ok by typing "help" in the IOC
shell -> either the "seq" or the "drvAsynIPPortConfigure" will be part
of the list of supported commands. I could also execute the state
machine from "makeBaseApp -t example".
If I try to write a Makefile which combines both features, "make" does
not complain (as it seems to me). But "help" in the ioc shell tells me
that "seq" is not a known command.
Can anyone explain what goes wrong here?
(The iocApp/src/Makefile of the "combined" IOC is attached)
Greetings,
Christoph
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
sequencer + streamdevice Christoph Burandt
Prev: Re: dbGetLink with options Andrew Johnson
Next: RE: sequencer + streamdevice Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: sequencer + streamdevice Christoph Burandt
