1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS support for USB TMC (Test & Measurement Class) devices -- Release 1.0
To: [email protected]
Date: Thu, 31 Oct 2013 10:07:20 +0900
Hi Eric,
(2013/10/31 2:14), Eric Norum wrote:
> The first production release of the ASYN USB TMC support module is
> available for downloads.
> This support module provides an asynOctet port that communicates with
> USB devices that implement the USB TMC (Test and Measurement Class)
> protocol. The support module uses the libusb-1.0 library and as such
> requires no special privileges or kernel drivers and should work
> across all platforms that support libusb-1.0.
> http://sourceforge.net/p/epics/wiki/ASYN%20USB%20TMC%20Support/
> The driver has been tested on Linux and OS X with assorted devices
> including an oscilloscope, a signal generator, a power meter and a
> magnetometer.
Nice Job!
For your infomation, there are python modules for USB-TMC.
https://pypi.python.org/pypi/python-usbtmc/0.1
https://pypi.python.org/pypi/PyUSBTMC/0.1dev04
These are not related to EPICS, but could be used to test your device
before developping EPICS database.
Noboru Yamamoto
Acclerator Control Group
J-PARC center
Noboru Yamamoto
Accelerator Control group
J-PARC center/KEK & JAEA
web: http://www-acc.kek.jp/EPICS_Gr/default.html
G+: https://plus.google.com/u/0/communities/116437315215298349838
Asyn asynDrvUser interface Paul Hamadyk
EPICS support for USB TMC (Test & Measurement Class) devices -- Release 1.0 Eric Norum
Prev: EPICS support for USB TMC (Test & Measurement Class) devices -- Release 1.0 Eric Norum
Next: Asyn asynDrvUser interface Paul Hamadyk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
