1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Asyn asynDrvUser interface
Date: Thu, 31 Oct 2013 10:11:01 +0000
I have a question about the asynDrvUser interface. I usually only define
a drvUserCreate function in order to set pasynUser->reason, and I set
drvUserDestroy to NULL. This worked until I added the asynFloat64
interface.
I've noticed that initAo() in devAsynFloat64.c calls
"pasynFloat64SyncIO->disconnect();" which calls
"pioPvt->pasynDrvUser->destroy()" and that initBo() in
devAsynUInt32Direct.c calls "pasynUInt32DigitalSyncIO->disconnect();"
which calls "pioPvt->pasynDrvUser->destroy()".
If asynDrvUser->destroy hasn't been defined then this clearly causes a
problem so:
1) Should I always be creating a destroy function?
static asynStatus drvUserDestroy(void *drvPvt, asynUser *pasynUser)
    return asynSuccess;
2) Why do only ao records with an AsynFloat64 interface and bo records
with an AsynUInt32Direct interface call disconnect() in their
initialisation function?
Paul.
RE: Asyn asynDrvUser interface Mark Rivers
EPICS support for USB TMC (Test & Measurement Class) devices -- Release 1.0 Eric Norum
Re: EPICS support for USB TMC (Test & Measurement Class) devices -- Release 1.0 Noboru Yamamoto
Prev: Re: EPICS support for USB TMC (Test & Measurement Class) devices -- Release 1.0 Noboru Yamamoto
Next: RE: Asyn asynDrvUser interface Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
