1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn asynDrvUser interface
To: Paul Hamadyk <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 31 Oct 2013 12:28:49 +0000
Hi Paul,
> If asynDrvUser->destroy hasn't been defined then this clearly causes a
> problem so:
> 1) Should I always be creating a destroy function?
Yes, you must always define a destroy function for the drvUser interface.
The definition of the interface is:
typedef struct  asynDrvUser {
    /*The following do not have to be called via queueRequest callback*/
    asynStatus (*create)(void *drvPvt,asynUser *pasynUser,
        const char *drvInfo, const char **pptypeName,size_t *psize);
    asynStatus (*getType)(void *drvPvt,asynUser *pasynUser,
    asynStatus (*destroy)(void *drvPvt,asynUser *pasynUser);
}asynDrvUser;
If you have registered the drvUser interface then you must implement all 3 functions.  Clients are not required to check that these function pointers are not NULL.
> 2) Why do only ao records with an AsynFloat64 interface and bo records
> with an AsynUInt32Direct interface call disconnect() in their
> initialisation function?
That is definitely an inconsistency and oversight which has been around for a very long time.  The disconnect() function should be called at the end of all of the record initialization functions that call the XXXSyncIO routines.  However, the penalty for not doing so is a very small amount of memory that gets allocated once and never released, so it is not really a problem.  It is not a memory leak that grows, because the record initialization routines are only called once.
____________________________
From: [email protected] [[email protected]] on behalf of Paul Hamadyk [[email protected]]
Sent: Thursday, October 31, 2013 5:11 AM
To: [email protected]
Subject: Asyn asynDrvUser interface
I have a question about the asynDrvUser interface. I usually only define
a drvUserCreate function in order to set pasynUser->reason, and I set
drvUserDestroy to NULL. This worked until I added the asynFloat64
interface.
I've noticed that initAo() in devAsynFloat64.c calls
"pasynFloat64SyncIO->disconnect();" which calls
"pioPvt->pasynDrvUser->destroy()" and that initBo() in
devAsynUInt32Direct.c calls "pasynUInt32DigitalSyncIO->disconnect();"
which calls "pioPvt->pasynDrvUser->destroy()".
problem so:
static asynStatus drvUserDestroy(void *drvPvt, asynUser *pasynUser)
    return asynSuccess;
Paul.
EPICS support for USB TMC (Test & Measurement Class) devices -- Release 1.0 Eric Norum
Re: EPICS support for USB TMC (Test & Measurement Class) devices -- Release 1.0 Noboru Yamamoto
Asyn asynDrvUser interface Paul Hamadyk
Prev: Asyn asynDrvUser interface Paul Hamadyk
Next: Re: merge multiple alarms Tito Körner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Channel access over wireless? Emmanuel Mayssat
