1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: BEAUTY Archiver and data from Area detector
To: Vítek Michal <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 8 Nov 2013 19:20:02 +0000
Hi Mike,
We are working on this task here,  in NSLS-II, in the context of the next version
of Channel Archiver.  You can learn about the approach from the recent EPICS
meeting: http://www.aps.anl.gov/epics/meetings/2013-10/
In short, the new version allows to use HDF5 for storing the conventional
time series of dbr data types and access them with the EPICS 4 RPC interface.
As a result, it creates a common platform for supporting images  and complex
data types.  Tentatively, we expect to release the “classical” version together
with the corresponding CSS plug-in in the end of November.  The support of
images however would require the development of a new  writer and  reader.
-Nikolay
From: [email protected] [mailto:[email protected]] On Behalf Of Vítek Michal
Sent: Friday, November 08, 2013 12:46 PM
To: [email protected]
Subject: BEAUTY Archiver and data from Area detector
Hello,
We would like to archive data from cameras (grabbed by EPICS IOC with area detector) with BEAUTY archiver. We have prepared testing setup with 1 camera (512x512 img, 25 FPS, grayscale), BEAUTY archiver, and MySQL db. Each block is running on independent computer, interconnection is over 1GB lan. The network traffic measured on the output of the EPICS IOC is ~6MB/s. The image can be displayed by Control System Studio intensity graph without problems.
I have also added following param to the BEAUTY configuration file:
org.csstudio.platform.libs.epics/max_array_bytes=300000
because it was complaining about the size of the incoming image.
The memory available for the Java programs is set to 2GB by OS Environmental variable.
When we start the archiver we can see that BEAUTY consumes all available resources (2GB of RAM and 99% CPU) in ~5s and then it crashes. When we changed the PV to be scanned every 5s then the BAUTY maintain to run consuming ~1GB of memory, and ~20% CPU and write duration  ~240s.
Thus I would like to ask if BEUATY is suitable for the archiving of images from camera or if I am doing something wrong…? Can anyone help me with this?
Cheers,
Mike
BEAUTY Archiver and data from Area detector Vítek Michal
Prev: Re: BEAUTY Archiver and data from Area detector Kasemir, Kay
Next: Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: BEAUTY Archiver and data from Area detector ulrik.pedersen
