1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: BEAUTY Archiver and data from Area detector
To: <[email protected]>, <[email protected]>
Date: Mon, 11 Nov 2013 09:05:57 +0000
Hi Mike,
I would recommend simply using one of the many file writing plugins that areaDetector ships with: you can store images in jpeg, tiff, netcdf, nexus and my personal favourite: hdf5. The list of supported formats is actually even longer as the GraphicsMagick plugin allow saving to any format the GraphicsMagick library supports... http://cars9.uchicago.edu/software/epics/NDPluginFile.html
Relational databases like mysql does not perform particularly well with constant streaming of image data. Certain file formats will do much better – especially when it is time to scale up a little bit (higher res. camera or higher framerate).
Cheers,
Ulrik
From: [email protected] [mailto:[email protected]] On Behalf Of Vítek Michal
Sent: 08 November 2013 17:46
To: [email protected]
Subject: BEAUTY Archiver and data from Area detector
Hello,
We would like to archive data from cameras (grabbed by EPICS IOC with area detector) with BEAUTY archiver. We have prepared testing setup with 1 camera (512x512 img, 25 FPS, grayscale), BEAUTY archiver, and MySQL db. Each block is running on independent computer, interconnection is over 1GB lan. The network traffic measured on the output of the EPICS IOC is ~6MB/s. The image can be displayed by Control System Studio intensity graph without problems.
I have also added following param to the BEAUTY configuration file:
org.csstudio.platform.libs.epics/max_array_bytes=300000
because it was complaining about the size of the incoming image.
The memory available for the Java programs is set to 2GB by OS Environmental variable.
When we start the archiver we can see that BEAUTY consumes all available resources (2GB of RAM and 99% CPU) in ~5s and then it crashes. When we changed the PV to be scanned every 5s then the BAUTY maintain to run consuming ~1GB of memory, and ~20% CPU and write duration  ~240s.
Thus I would like to ask if BEUATY is suitable for the archiving of images from camera or if I am doing something wrong…? Can anyone help me with this?
Cheers,
Mike
BEAUTY Archiver and data from Area detector Vítek Michal
Prev: Error while opening OPI Swati Soni2
Next: Re: Subscription updates halting? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: BEAUTY Archiver and data from Area detector Malitsky, Nikolay D
Next: Subscription updates halting? Gibbs, Matt
