1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Subscription updates halting?
Date: Sun, 10 Nov 2013 02:46:19 -0800
Hi everyone,
I’m trying to write a Channel Access client interface to node.js using libca, and I am running into a puzzling issue.
I have a simple test script where I create a channel, then create a new subscription, and pass in an event callback function which just prints the current value of the PV to the terminal.  Most of the time, this works great, but maybe 20% of the time, I get two updates, then nothing else for the duration of the program.  This is always using the same code, with the same PV.  If I run ‘camonitor’ on the PV repeatedly, I never see the same problem.
I don’t get any exception messages, and the rest of the script doesn’t crash or halt, so it seems like the event callback just stops getting called.
Any ideas about what might be happening, or things I can do to further debug this?
Thanks!
—Matt
Re: Subscription updates halting? Dirk Zimoch
Re: Subscription updates halting? Andrew Johnson
Prev: Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Next: Error while opening OPI Swati Soni2
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: BEAUTY Archiver and data from Area detector ulrik.pedersen
Next: Re: Subscription updates halting? Dirk Zimoch
