1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PV access over the Network.
To: [email protected]
Date: Tue, 12 Nov 2013 02:05:16 +0530
Dear All,
I am trying to access PVs between three linux machine through the Wired Ethernet and Switch . Each machine have EPICS and CSS installed. Firewall is disabled.
Static IP addresses are 192.168.100.1, 192.168.100.2, 192.168.100.3
Subnet mask 255.255.255.0 and Gateway 192.168,100,50 is common on all machines.
Made one IOC and one Application on each machine using makeBaseApp.pl. PV of each IOC are running well and accessible from CSS OPI at local machine.
But many times I could not access the same PV on another CSS OPI in other linux machine over the LAN even with camonitor command. What cause this uncertainty.
I tried with multiple Environment Variable configuration.
like:
[GMRT@01HW183138 ~]$ set | grep EPICS
EPICS_APP=/home/GMRT/Desktop/epics/app
EPICS_BASE=/home/GMRT/Desktop/epics/base-3.14.12.3
EPICS_CA_ADDR_LIST=192.168.100.1 192.168.100.2 192.168.100.3
EPICS_CA_AUTO_ADDR_LIST=NO
#EPICS_CA_ADDR_LIST=localhost
EPICS_EXTENSIONS=/home/GMRT/Desktop/epics/extensions
EPICS_HOST_ARCH=linux-x86_64
EPICS_IOC=/home/GMRT/Desktop/epics/ioc
EPICS_ROOT=/home/GMRT/Desktop/epics
EPICS_SUPPORT=/home/GMRT/Desktop/epics/support
EPICS_SUPPORT_LOCAL=/home/GMRT/Desktop/epics/support_local
Could you please tell me what I missing here.Where the role of CaClient will come.
Also please help me with following errors
1: CA beacon (sent to "192.168.100.3:5065") error was "Connection Refused" and this automatically goes off when I try multiple time.
2: CA.Client.Exaception..............................................
Warning : "Empty PV search address list"
3: PV not found... error with "camonitor" command on local machine but same PV is working in CSS OPI .
  Many time this thing goes of when I run camonitor as a root.
4: What is Ideal directry in linux to install the EPICS base, where all user can use the EPICS base, without going in to root.
Thanks and Regards
Ganesh Jangir
TCS, India
Notice: The information contained in this e-mail
message and/or attachments to it may contain
confidential or privileged information. If you are
not the intended recipient, any dissemination, use,
review, distribution, printing or copying of the
information contained in this e-mail message
and/or attachments to it are strictly prohibited. If
you have received this communication in error,
please notify us by reply e-mail or telephone and
immediately and permanently delete the message
and any attachments. Thank you
Re: PV access over the Network. Maurizio Montis
Prev: Re: autosave failure S_rpcLib_RPC_CANTSEND Andrew Johnson
Next: Re: autosave failure S_rpcLib_RPC_CANTSEND J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Error while opening OPI Kasemir, Kay
Next: Re: PV access over the Network. Maurizio Montis
