1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV access over the Network.
To: Ganesh Jangir <[email protected]>
Cc: [email protected]
Date: Tue, 12 Nov 2013 09:57:06 +0100 (CET)
Hi Ganesh,
for the problem related to PV remote access trought CSS OPI, have you
configured the EPICS_CA_ADDR_LIST variable into the CSS application?
Under Preferences -> CSS Core -> EPICS you find the "CSS"
EPICS_CA_ADDR_LIST.
Hope this helps
- Maurizio
On Nov 11, 2013 09:35 PM, Ganesh Jangir <[email protected]> wrote:
> Dear All,
> I am trying to access PVs between three linux machine through the
> Wired Ethernet and Switch . Each machine have EPICS and CSS installed.
> Firewall is disabled.
> Static IP addresses are 192.168.100.1, 192.168.100.2, 192.168.100.3
> Subnet mask 255.255.255.0 and Gateway 192.168,100,50 is common on all
> machines.
> Made one IOC and one Application on each machine using makeBaseApp.pl.
> PV of each IOC are running well and accessible from CSS OPI at local
> machine.
> But many times I could not access the same PV on another CSS OPI in
> other linux machine over the LAN even with camonitor command. What
> cause this uncertainty.
> I tried with multiple Environment Variable configuration.
> like:
> [GMRT@01HW183138 ~]$ set | grep EPICS
> EPICS_APP=/home/GMRT/Desktop/epics/app
> EPICS_BASE=/home/GMRT/Desktop/epics/base-3.14.12.3
> EPICS_CA_ADDR_LIST=192.168.100.1 192.168.100.2 192.168.100.3
> EPICS_CA_AUTO_ADDR_LIST=NO
> #EPICS_CA_ADDR_LIST=localhost
> EPICS_EXTENSIONS=/home/GMRT/Desktop/epics/extensions
> EPICS_HOST_ARCH=linux-x86_64
> EPICS_IOC=/home/GMRT/Desktop/epics/ioc
> EPICS_ROOT=/home/GMRT/Desktop/epics
> EPICS_SUPPORT=/home/GMRT/Desktop/epics/support
> EPICS_SUPPORT_LOCAL=/home/GMRT/Desktop/epics/support_local
> Could you please tell me what I missing here.Where the role of
> CaClient will come.
> Also please help me with following errors
> 1: CA beacon (sent to "192.168.100.3:5065") error was "Connection
> Refused" and this automatically goes off when I try multiple time.
> 2: CA.Client.Exaception..............................................
> Warning : "Empty PV search address list"
> 3: PV not found... error with "camonitor" command on local machine but
> same PV is working in CSS OPI .
>   Many time this thing goes of when I run camonitor as a root.
> 4: What is Ideal directry in linux to install the EPICS base, where
> all user can use the EPICS base, without going in to root.
> Thanks and Regards
> Ganesh Jangir
> TCS, India
> Notice: The information contained in this e-mail
> message and/or attachments to it may contain
> confidential or privileged information. If you are
> not the intended recipient, any dissemination, use,
> review, distribution, printing or copying of the
> information contained in this e-mail message
> and/or attachments to it are strictly prohibited. If
> you have received this communication in error,
> please notify us by reply e-mail or telephone and
> immediately and permanently delete the message
> and any attachments. Thank you
PV access over the Network. Ganesh Jangir
Prev: DS6064 Zenon Szalata
Next: C863 can't answer the PI GCS commands Mi Qingru
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: PV access over the Network. Ganesh Jangir
Next: DS6064 Zenon Szalata
