1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: LIB_INSTALLS, static builds and .so files.
To: "Shankar, Murali" <[email protected]>
Date: Wed, 13 Nov 2013 17:32:10 -0600
Hi Murali,
On 11/13/2013 05:17 PM, Shankar, Murali wrote:
My question is about how to add avcodec to the product (executable)
correctly? Should I use |USR_LIBS| or |PROD_LIBS| or something else? All
of these seem to give me various make/linker errors. I’d like to stay
within the EPICS build system to solve the problem of
1)Include an external library in your install package using LIB_INSTALLS
2)Include it in your product using xyz…
Do you actually need to install a copy that library, or are you just doing that to try and get it to work?
To link a program with an external library you add the library name to the _LIBS variable as usual, then you just tell the build system where that library can be found by setting its *_DIR variable. In your case I think you just need these lines in the Makefile that is building the executable:
avcodec_DIR = $(PACKAGE_SITE_TOP)/ffmpeg/$(FFMPEG_MODULE_VERSION)/lib
xxx_LIBS += avcodec
  to link it into just the program 'xxx', or
PROD_LIBS += avcodec
if you're building multiple programs and want this linked into all of them.
If that doesn't work my memory may be slightly off, but I think it's right.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
LIB_INSTALLS, static builds and .so files. Shankar, Murali
Prev: LIB_INSTALLS, static builds and .so files. Shankar, Murali
Next: Re: areaDetector for a Basler GigE camera Florian Sorgenfrei
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Substitutions defaults and tricks Brown, Garth
