1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: areaDetector for a Basler GigE camera
Date: Thu, 14 Nov 2013 18:27:53 +0100
Hi Mark,
that is good to hear that it's just a few files missing. Indeed my ARCH
is linux-x86_64. The error which came during compilation was  'No rule
creating the target../../../lib/linux-x86_64/libnetCDF.a,
  mandatory for example.  Stop.'
I downloaded the package you sent and do my best in getting this working.
Meanwhile I'm wondering whether this is something different as compared
to the aravisGigE package from the DLS. I was pointed to those packages
since I read that the aravis library is able to communicate with the
Basler cameras. Indeed I was just using arv-camera-test and it created
the following output
xxx@yyy:~/devel/testiocBasler/aravisGigE-0-1-15dls6/vendor/aravis-linux-x86_64/tests$
./arv-camera-
test -n Basler-21342763
Looking for camera 'Basler-21342763'
vendor name         = Basler
model name          = scA640-74gm
device id           = 21342763
image width         = 659
image height        = 494
horizontal binning  = 1
vertical binning    = 1
exposure            = 4000 µs
gain                = 320 dB
Frame rate = 59 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 79 Hz
Frame rate = 80 Hz
^CFrame rate = 78 Hz
Completed buffers = 849
Failures          = 0
Underruns         = 0
From comparing the st.cmd files I understand that both cameras
initialized (sorry for the sloppy use of this word) using
NDStdArraysConfig(). However in my aravis development folder I have the
command aravisCameraConfig(...) while in your distribution I have
prosilicaConfig(...). From what I have learned so far I believe that the
dbd files ('registrar("aravisCameraRegister")' and
'registrar("prosilicaRegister")') are doing this. Can I just copy the
dbd file (and presumably adopt some files like configure/RELEASE and
what else needs to be changed) before compiling to get that working or
is it a bigger effort?
Cheers,
Flo
Florian Sorgenfrei
Institute for Methods and Instrumentation for Synchrotron Radiation
Research G-ISRR
Albert-Einstein-Str. 15
D-12489 Berlin
GERMANY
Tel.: +49 30 8062 12924
Fax: +49 30 8062 14987
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
RE: areaDetector for a Basler GigE camera Mark Rivers
areaDetector for a Basler GigE camera Sorgenfrei, Florian
Prev: Re: LIB_INSTALLS, static builds and .so files. Andrew Johnson
Next: RE: areaDetector for a Basler GigE camera Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: areaDetector for a Basler GigE camera Mark Rivers
