1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: The results of your email commands
To: techtalkForo <[email protected]>
Date: Fri, 15 Nov 2013 12:59:06 +0000 (GMT)
Hello,
I have changed from double to integer a couple of record. I have done these changes both in the database and in the driver. I have done this many, many times. PVs  now work properly, read and write the values as before, but this common error appears in the IOC:
C:\Epics\applications\lyrtech\iocBoot\iocdrvLyrtechVhs>..\..\bin\win32-x86\drvLyrtechVhs.exe st.cmd
dbLoadDatabase("../../dbd/drvLyrtechVhs.dbd")
drvLyrtechVhs_registerRecordDeviceDriver(pdbbase)
# Turn on asynTraceFlow and asynTraceError for global trace, i.e. no connected asynUser.
#asynSetTraceMask("", 0, 17)
drvLyrtechVhsConfigure("dlVHS", 1000)
Board VHS-ADC-8/16 found! -> Slot ID[0]
Board VHS-ADC-8/16 found! -> Slot ID[1]
2 VHS boards detected!!!
Displaying VHS-ADAC Info...
FPGA Programming Loops...SUCCESS!!!Press enter
Clock is External
FPGA Programming Diagnostics...SUCCESS!!!Press enter
Clock is External
Presione una tecla para continuar . . .
dbLoadRecords("../../db/drvLyrtechVhs.db","P=RF:,R=LLRF_,PORT=dlVHS,ADDR=0,TIMEOUT=1,NPOINTS=1000")
#asynSetTraceMask("dlVHS",0,0xff)
asynSetTraceIOMask("dlVHS",0,0x2)
#set_requestfile_path("C:/EpicsR3.14.11/applications/iocBoot")
#set_savefile_path("C:/EpicsR3.14.11/applications/iocBoot")
#set_pass1_restoreFile(auto_settings.sav)
#save_restoreSet_DatedBackupFiles(1)
iocInit()
Starting iocInit
## EPICS R3.14.11 $R3-14-11$ $2009/08/28 18:47:36$
## EPICS Base built Jun 27 2013
2013/11/15 13:40:22.739 asynPortDriver:setDoubleParam: port=dlVHS error setting parameter 0 in list 0, wrong type
2013/11/15 13:40:22.740 asynPortDriver:setDoubleParam: port=dlVHS error setting parameter 0 in list 0, wrong type
# save other things every five seconds
#create_monitor_set("auto_settings.req", 5 ,"P=RF:", "R=LLRF")
epics> 2013/11/15 13:40:23.238 asynPortDriver:setDoubleParam: port=dlVHS error setting parameter 0 in list 0, wrong type
2013/11/15 13:40:23.239 asynPortDriver:setDoubleParam: port=dlVHS error setting parameter 0 in list 0, wrong type
I have fixed this error many times, I know how it works, but now I have spent two days, repeating the proccess and I don't find anything. Everything looks fine and works fine but that appears every second, every time the readData function runs, I think.
Any idea?.
Many thanks.
Julio.
Prev: Substitutions defaults and tricks Brown, Garth
Next: Re: Substitutions defaults and tricks Pietryla, Anthony F.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Substitutions defaults and tricks Emmanuel Mayssat
Next: Job Announcement: US ITER Instrumentation & Controls Group Leader - 1st of a kind fusion reactor, international partnership, management role Cherry, Steve J.
