1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Substitutions defaults and tricks
To: [email protected]
Date: Sat, 16 Nov 2013 08:45:02 -0500
On 11/15/13 19:42, Andrew Johnson wrote:
> ...If you want
> to try out the new msi it should be possible to extract just the
> src/ioc/dbtemplate/msi.c file and build it against a 3.14.12 version of
> Base.
FYI this patch applies against 3.14.12.3.  Be aware that it includes an
ABI change which is adding a second argument to dbLoadTemplate().
Although this won't be an issue when invoked from the IOC shell.
https://raw.github.com/epicsdeb/epics-base/master/debian/patches/0025-backport-msi-join-branch-from-3.15.patch
Substitutions defaults and tricks Brown, Garth
Re: Substitutions defaults and tricks Pietryla, Anthony F.
RE: Substitutions defaults and tricks Brown, Garth
Re: Substitutions defaults and tricks Andrew Johnson
Prev: Re: Substitutions defaults and tricks Bruce Hill
Next: RE: epics with eclipse Brown, Garth
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <2013>  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Substitutions defaults and tricks Emmanuel Mayssat
